Comin your way.
- First Name: Herb
- Last Name: Iffrig
Re: Comin your way.
Thanks Tom. I always appreciate seeing a Torpedo photo. Two of them today is a bonus.
- First Name: Noel
- Last Name: Chicoine
Re: Comin your way.
What type of starter assist is on the first early Ford picture? I see a vertical crank handle above some apparatus.
- First Name: Erik
- Last Name: Johnson
Re: Comin your way.
That's the water pump - not a starter.
Re: Comin your way.
Don't remember the name of that crank up device, but it works like an electric starter. There is a spring in it which you can crank up and then release the spring and it will start your engine, Good for a magneto without any battery to the coils because it can make continuous spin of the crank instead of the hand crank which gives one spark each time you pull the crank.
Re: Comin your way.
I love the Bevo truck. That's a wonderful photo.
- First Name: Bill
- Last Name: Witmer
- * REQUIRED* Type and Year of Model Ts owned: 1907 Model N,1914 Runabout
Re: Comin your way.
Always like to see the N R S Ford photos. Thank you for posting.
- First Name: Kurt
- Last Name: Baltrusch
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1918 Touring, 1922 Sedan
Re: Comin your way.
Photo 6 is a very rare Doctor's Roadster!
