Oil
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Oil
Post by Will » Sun Jul 13, 2025 9:01 am
Not one auto parts in my area is carrying conventional motor oil, Its all either a full synthetic or a blended synthetic oil. I was lucky to find a five gallon pail at my local NAPA of 30# conventional for the model T which should hold me for a very long time as I don't drive the T very much anymore. I was running 15/40 Rotella but thats even getting hard to find. I had to special order conventional for my daily drivers of which I got 4 of each for my drivers. I'm not certain how the T will run on the synthetic when there is no longer any conventional left. Do you guy feel it will effect the Babbitt bearings?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Oil
Post by Erik Johnson » Sun Jul 13, 2025 10:55 am
Walmart Supertech SAE HD-30 conventional motor is readily available, at least where I live. However, it's typically not in the automotive department but in the area where they sell lawnmowers or lawnmower sundries/yard and garden. They also sell SAE 30 non-detergent for air compressors but it is not labeled as automotive engine oil (even though it would be no problem to use it in a Model T or brass auto).
For anyone in the midwest, SAE HD-30 is also readily available at Menards - however, it is in the lawnmower department and not the automotive department.
It's been a while since I've bought SAE 30 detergent or non-detergent at an auto parts store. I go to a lot of estate sales here in the Twin Cities and always pick up SAE 30 and 10W-30 when I find it and usually spend no more than a dollar a quart. I recently bought a case of Valvoline 10W-30 at an estate sale.
Re: Oil
Post by TXGOAT2 » Sun Jul 13, 2025 11:47 am
Synthetic oil works well in a Model T. 10W30 is a good choice in most parts of the USA. Ford recommended 20W. 10W30 covers that nicely. If you run a T in cold weather, 5W20 is a good choice.
First Name: john
Last Name: karvaly
Re: Oil
Post by speedytinc » Sun Jul 13, 2025 11:51 am
Napa, on line & locally, has 30wt detergent & non detergent in their brand & valvoline 30 racing.
varmint
First Name: Vernon
Last Name: Worley
Re: Oil
Post by varmint » Sun Jul 13, 2025 1:42 pm
https://www.autozone.com/motor-oil-and- ... 811768_0_0
You should be able to order this in store or online. If this is what you are looking for.
Vern (Vieux Carre)
Re: Oil
Post by Steve Jelf » Sun Jul 13, 2025 2:03 pm
In a rural small town, the local Walmart may have synthetic only.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Oil
Post by big2bird » Sun Jul 13, 2025 4:28 pm
Amazon.
I just bought 5 qts 0-20 fully synthetic Valvoline Dexos for my truck. $22.93. Can't beat that.
I assume they have VR-1 30wt as well.
I use VR-1 in any engine i rebuild that has flat tappet cams, period.
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1929 Model A Tudor
Re: Oil
Post by NealW » Sun Jul 13, 2025 5:07 pm
If you live near an Atwoods, they sell conventional motor oil; at least the one near me does.
love2T's
First Name: T
Last Name: Gates
Re: Oil
Post by love2T's » Sun Jul 13, 2025 10:20 pm
Menards, rural king, even wal mart handle ordinary Rotella 10W30. Stick with that..you can't go wrong.
Will
First Name: Will
Last Name: Copeland
Re: Oil
Post by Will » Mon Jul 14, 2025 7:38 am
A long time ago I had asked about running synthetic oils in the T and was warned to never ever put synthetic based oils in any engine with babbit bearings. I was also told it would destroy the clutches in the T because it was to slippery. I'm certain that at some point there will no longer be conventional oils as todays modern cars all use synthetic based oils. Has anyone actually used synthetic oils in there T's and what was the out come? I'd appreciate some builders chime in on this question with there experience. I have a feeling that we are slowly regressing back to the days of buying are gas and oil from the local pharmacy.
Re: Oil
Post by TXGOAT2 » Mon Jul 14, 2025 8:08 am
My Model T has run the Montana 500 using full synthetic oil. It has stock bearings and crankshaft. I have run full synthetic 5W20 or 10W30 oil in it for over 15,000 miles at speeds up to 45+ MPH with no issues what so ever. Multi-grade full synthetic motor oil meets, and FAR exceeds, Ford's specifications for motor oil. I have excellent transmission band and clutch function. My car does have Kevlar bands. The stock magneto works well. Oil consumption is minimal, as is leakage. The car has aluminum pistons and modern type rings and a performance cam. I run this car mostly on the open road in warmer weather, up to 105 F. The car is equipped with an oiled foam type air filter and a New Day timer and a Texas T auxiliary oiler.
Re: Oil
Post by TXGOAT2 » Mon Jul 14, 2025 8:22 am
Old, high mileage engines with oil pumps and full pressure lubrication do very well using Wal Mart 20W50 conventional oil. In hot weather, adding a pint of STP can be beneficial. An exception would be old model Chevrolet sixes and others with splash type rod bearings. These engines require a light bodied oil, especially in cold weather. I put oil designed for diesel engines in diesel engines. There are very few vehicles that require high ZDP oil, and model Ts are not among them.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Oil
Post by Rich P. Bingham » Mon Jul 14, 2025 9:03 am
Oil ? Yes ! Use it !! :lol:
Get a horse !
Will
First Name: Will
Last Name: Copeland
Re: Oil
Post by Will » Mon Jul 14, 2025 9:22 am
Thanks everyone, That answered my questions. Maybe I will take that 5 gallon pail of NAPA 30# back and start running synthetic oil in it on my next oil change.
John Codman
Last Name: Codman
Re: Oil
Post by John Codman » Mon Jul 14, 2025 11:14 am
My 2005 Dodge 5.7 Hemi calls for non-synthetic engine oil. I have never had any difficulty in finding it. Auto Zone stocks it, and so does the local Firestone and Goodyear stores. I also can get Shell Rotella T-4 and Shell Formula 10 W 30 in a Walmart about 15 miles from my house. Despite it's name, the Shell Formula is intended for gasoline engines. The T-4 is intended for light and heavy Diesels, but I have no qualms with using it in my low-revving Model T.
Re: Oil
Post by TXGOAT2 » Mon Jul 14, 2025 11:49 am
Will, since you live in Florida, you should have no issues using a good quality 30W non-detergent oil in a Model T, especially if your engine has at least a few hundred miles on it. If I were you, and already had the 30W, I'd go ahead and use it. You can improve the non-detergent, straight grade oil's performance by adding about 25% Marvel Mystery Oil to it. That will assure good lubrication at start-up, make starting easier, reduce clutch drag, and prevent internal engine deposits. In this area, Wal Mart still carries conventional multi-grade oils most of the time. In Florida, I'd use 10W30 detergent oil in a Model T, either conventional or synthetic.
Craig Leach
First Name: craig
Last Name: leach
Re: Oil
Post by Craig Leach » Mon Jul 14, 2025 2:00 pm
Just for the record has anyone had issues with running synthetic motor oil in their model T? I never have not knowing it's effect on band function
but modern automatics seem to be OK with it & that is the same principle in function as far as bands go.
Craig.
BarnesvilleT
First Name: William
Last Name: Hallada
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: Oil
Post by BarnesvilleT » Thu Jul 17, 2025 12:03 pm
A year or so ago I had the same question about oil and it was suggested to me to use Shell Rotella T4 15w40.
From someone that professionally builds T engines and a lot of them. I have ran this oil in my rebuilt engine from the start.
So far so good.
Bill
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Re: Oil
Post by WillyR » Thu Jul 17, 2025 12:13 pm
Napa usually has an online coupon for 10-20% off over $125 purchases.
I usually fill the munny gap with whatever oils are on sale.
I buy the napa branded rotella by the gallon, along with gear oil...
your bucket of 30w would be just fine.
some members of our club use synthetic some don't.
I don't because I do change oil semi-frequently, in all my cars.
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
Re: Oil
Post by Norman Kling » Thu Jul 17, 2025 12:20 pm
I use Vaovoline synthetic from Walmart. Everything in my T is stock except Kevlar bands. I have not experienced problems with the oil. At least not anymore than with other oils except that there is much less sludge in the crankcase than with the pariffin based oils.
