Any tips on a fan belt tach drive?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Tue Jul 15, 2025 1:15 pm
I have a great old tachometer that reads in hundreds of RPMs that I am using on my speedster. A while back I saw a tachometer drive that ran off the fan belt in a picture of an English car, but I can’t find the picture and have never seen another. Have any of you made, used, or seen a belt driven tachometer drive on a T or other car? If so, I am interested in any information on what works and how to make one.
Re: Any tips on a fan belt tach drive?
Post by Steve Jelf » Tue Jul 15, 2025 1:58 pm
I don't know about belt drive, but tachometers are a common item for sale on the net at a wide range of prices.
Post by DanTreace » Tue Jul 15, 2025 2:40 pm
Older post on tach installs
Scroll down and photo of fan pulley drive using an o-ring as drive belt.
https://www.mtfca.com/discus/messages/1 ... 1296400655
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Jul 15, 2025 2:59 pm
Hi Morgan,
A while back someone was looking for info on adjusting the speed of a tach drive that came off the back of the generator. But no on the fan
which will maybe need the same ratio change made.
Craig.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue Jul 15, 2025 3:16 pm
I like the one that runs off the fan hub. That would be a simple way to do it and using a rubber drive rather than the belt would be simple. I would need to do some calculations to get the ratio right. The mounting is pretty easy as well. The only difference is I am using the 1926 water outlet/fan hub.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Jul 15, 2025 3:21 pm
The ones I have seen Morgan used a rubber wheel as you are stating with light spring pressure from an arm. Turned out it was pretty accurate.
