When it was new and when it wasn’t.
- Last Name: House
Re: When it was new and when it wasn’t.
Interesting then-and-now contrast in the 2 photos. I have an early ‘26 roadster without a headlamp bar, a black sheetmetal radiator shell and nickeled headlamp rims. The top photo appears to be somewhat high in the front although it has correct spindles…..Thanks Tom for this morning’s entertainment.
1927, with wood wheels and 30 x 3-1/2 tires. Not unheard of but interesting just the same.
- Last Name: Hunt
- * REQUIRED* Type and Year of Model Ts owned: '26 Runabout
I was thinking it was a '26. (I have a '26 just like it, but with wire wheels) Teach me something here.....what are the differences in the '26 & '27?Jerry VanOoteghem wrote: ↑Wed Jul 16, 2025 9:14 am1927, with wood wheels and 30 x 3-1/2 tires. Not unheard of but interesting just the same.
I was going simply by the "brand new" look of the car and its 1927 license plate. Also, the nickel radiator shell, ('26 open cars tended to have black shells). In '26, wire wheels were optional and 21" wood wheels were standard. In '27 it was the other way around. A few owners, however, chose to have the 30 X 3-1/2 clincher tires/wheels. These were mainly fleet owners who had a ready supply of 30 x 3-1/2" tires in their service areas and did not want to stock a new, different size tire.CatGuy wrote: ↑Wed Jul 16, 2025 10:38 amI was thinking it was a '26. (I have a '26 just like it, but with wire wheels) Teach me something here.....what are the differences in the '26 & '27?Jerry VanOoteghem wrote: ↑Wed Jul 16, 2025 9:14 am1927, with wood wheels and 30 x 3-1/2 tires. Not unheard of but interesting just the same.
That being said, I could still be wrong...
Last edited by Jerry VanOoteghem on Wed Jul 16, 2025 11:53 am, edited 1 time in total.
- Last Name: Hunt
Oh, I hadn't looked at the plate. Still, it does make me curious about how to tell the two apart. I've always wondered if I actually have a '27.Jerry VanOoteghem wrote: ↑Wed Jul 16, 2025 11:50 amI was going simply by the "brand new" look of the car and its 1927 license plate. In '26, wire wheels were optional and 21" wood wheels were standard. In '27 it was the other way around. A few owners, however, chose to have the 30 X 3-1/2 clincher tires/wheels. These were mainly fleet owners who had a ready supply of 30 x 3-1/2" tires in their service areas and did not want to stock a new, different size tire.CatGuy wrote: ↑Wed Jul 16, 2025 10:38 amI was thinking it was a '26. (I have a '26 just like it, but with wire wheels) Teach me something here.....what are the differences in the '26 & '27?Jerry VanOoteghem wrote: ↑Wed Jul 16, 2025 9:14 am1927, with wood wheels and 30 x 3-1/2 tires. Not unheard of but interesting just the same.
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster’s,51 Mercury 4 door sport sedan, 67 Mercury Cougar
The car is a 1927 with the head lights mounted on the fender tie bar plus it has 1927 license plate. Those wheels are the 21 inch by 4:50 split rims , notice the straight side rim on the right front wheel.
- First Name: Vilhelm
- Last Name: VonRaschke
- * REQUIRED* Type and Year of Model Ts owned: 1924 coupe
remember, new plates were issued with the same number, every year.
up until the 60/70"s in some states.
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
The cross section shape would come closest to the balloon tire rims because the earlier 30 x 3.5 inch would have a cross section that curves toward the tire.
- Last Name: van Ekeren
It might be the angle of the photo or snow on the core, but that radiator looks to have the cooling fins removed.
