Spare Tire Bracket
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Spare Tire Bracket
Post by Rod » Fri Jul 18, 2025 4:20 pm
Does anyone recognize this spare tire holder? The clip on the bottom fell off and I need replace it.
Thanks,
Rod
Re: Spare Tire Bracket
Post by speedytinc » Fri Jul 18, 2025 4:40 pm
This is the most common factory carrier. Missing the carriage bolt stud & the locking plate.
Post by Steve Jelf » Fri Jul 18, 2025 5:15 pm
I happen to have the same carrier. One of the lugs on my Hayes rim goes at the bottom and the carriage bolt takes a lug nut to hold the rim in place. For a rim without lugs, I gather you'll need a spare lug and nut to go on the bolt.
Post by speedytinc » Fri Jul 18, 2025 5:32 pm
The way you have the spare mounted is not correct. The rim lug doesn't attach to the lower bracket. You are missing the clamp #2849D.
The rim should be rotated 45 degrees. The clamp is held by a lug nut. The upper part of the clamp has a hole & slot for a padlock.
You don't need to take my word for it. Look @ factory photos.
Post by John kuehn » Fri Jul 18, 2025 6:57 pm
The parts you need are on this page from Lang’s. The bolt, clamp and nut. https://www.modeltford.com/pl.aspx?t=s& ... amp&page=1
This should give you an idea of what parts you need for your spare tire bracket.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Jul 19, 2025 6:25 am
This is how it is on my 1924 Runabout.
