Failure to proceed…
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Failure to proceed…
Post by Reno Speedster » Thu Jul 17, 2025 2:14 am
I went out tonight for dinner with the car club and my 22 conked out as I pulled into the parking lot. It has spark and compression so it is a fuel issue. Turns out my NH carb was pouring out gas. I tapped it and the fuel stopped. Then I could start it and it would run fine but would conk out after a bit, I think when the float was overwhelmed and it flooded. It was getting late so some friends towed me home. It was my first “failure to proceed” in the T. Here is a photo to commemorate the occasion. I will pull the carb and get it sorted. Luckily, I just ordered one of Scott Congers full flow valves to put it while I have it out.
Last edited by Reno Speedster on Fri Jul 18, 2025 12:13 am, edited 1 time in total.
First Name: Adrian
Last Name: Whiteman
Re: Failure to proceed…
Post by A Whiteman » Thu Jul 17, 2025 4:22 am
Well Morgan, sorry to say but: 'Welcome to the Club'
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Jul 17, 2025 7:01 am
Reno Speedster ..... Dirt, sediment, rust, old gas Gunk,.... will keep any inlet valve from properly closing. When was your gas supply system or carburetor last cleaned out?.... Curious to what you will find.
Post by TXGOAT2 » Thu Jul 17, 2025 7:32 am
See the recent thread on carburetor flooding.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Thu Jul 17, 2025 8:55 am
Not a huge deal since it occurred pretty close to home when I had a lot of help. The fuel system is very clean (no rust in the tank, rebuilt NH carb etc.). It has been a couple of years but not that many miles since I had the carb out. The tank is full, which may be contributing to the issue (pressure in the line overwhelming the float). But it was running fine for 30 or so miles (a car show and the 4th of July parade) after I filled the tank. I will get the carb apart and figure it out.
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Thu Jul 17, 2025 9:27 am
just guessing but sounds like the float has a hole in it and IT is flooded with fuel in it. (FWIW I call it the "toilet seat" :lol: )
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Jul 17, 2025 9:38 am
A stuck open valve is usually dirt, or a bad float, or both. If you take the float out and shake it you will hear if it has a leak and taken on gas.
WillyR
First Name: Vilhelm
Last Name: VonRaschke
* REQUIRED* Type and Year of Model Ts owned: 1924 coupe
Post by WillyR » Thu Jul 17, 2025 11:20 am
little piddly things that cause break downs are the worst.
Sent from the panic room, via two tin cans attached with a string, and a jail broken Marconi, while wearing a Tin Foil hat.
Post by speedytinc » Thu Jul 17, 2025 11:37 am
Drain the bowl into a glass jar looking for contaminants. Doesnt take much, but often clears itself.
Look for a worn spot on the float tab that can hold up the needle from occasionally not seating.
Look for possible float hang ups @ the bowl edge or center stem & float centering.
Sounds mostly like a sticky needle & seat. Sticking open & closed intermittently.
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Thu Jul 17, 2025 11:52 am
After you check the float also check your gas cap to make sure that the vent hole is still open. If the vent becomes blocked then a partial vacuum will form in the tank causing air to be sucked into the fuel from the carburetor end of the fuel line. If you started with a full tank all will be ok but as you drive the gas goes down and air has to enter the gas tank to fill that space, so sense you said it ran fine for 30 miles it would have used about two gallons and at that point with a blocked cap vent air would have found its way into the tank some how.
Another possibility is that a full gas tank if fairly cool gas , got warm expanding the gas , and over loading the carburetor float. But if you were in low gear a lot for the time I would think if the cap vent was ok the gas would go down fast enough for that not to happen.
Post by Norman Kling » Thu Jul 17, 2025 12:30 pm
Quite a few years we had a tour with about 50 cars on it. We stopped in a town along the way to get gas. There were two stations. Those who stopped at one station, unfortunately, the one I stopped at. Went a few miles and their engines stalled. Those who used the other station didn't have any problems. After draining the sediment bowl and the carburetor bowl, It started and ran fine the rest of the tour. Apparently there was sediment and water at the bottom of the tank at the station. Those things can happen. and do. A fuel filter would help, but they don't work very well with gravity flow systems.
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Thu Jul 17, 2025 1:22 pm
I hope you didn't hurt the forth main by pulling it home? If in neutral that doesn't get oil.
Moxie26
Post by Moxie26 » Thu Jul 24, 2025 7:51 pm
Reno Speedster.... How did you make out cleaning and rebuilding your carburetor?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Thu Jul 24, 2025 9:29 pm
I have not had a chance to take it apart yet. I got a new float, needle, seat, and gasket set but I am waiting for a full flow valve to come before I dive in. While I have it out I am going to replace the freeze plugs and maybe install a Z head I have on the speedster engine, which is getting a Rajo BB. I will make a report when I get it done.
Post by Steve Jelf » Thu Jul 24, 2025 10:49 pm
Freeze plugs? If you want them to be period correct...
https://dauntlessgeezer.com/DG87.html
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat Aug 02, 2025 10:47 pm
Update:
I finally had the chance to pull the carburetor and I found it was a simple fix. For some reason the float needle seat had come loose and threaded out. This messed up the float adjustment and jammed the float. The carb is a clean rebuild and everything else was fine. I installed a new full flow needle and seat (which I was planning to do anyway), snugged it down, and adjusted the float height. I won’t be able to run it till tomorrow, but I think I found the culprit.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Aug 03, 2025 9:20 am
I had the same thing happen to me. In the middle of nowhere. crawled under and fixed it and was on the road in 15 minutes. only time my T's ever let me down.
John Codman
Last Name: Codman
Post by John Codman » Sun Aug 03, 2025 2:54 pm
The only time(S) that I have had to call AAA was due to crud in the Carburetor. It didn't take long to figure out that the crud was from the fuel tank. I drained the tank through a paint strainer and used the gas in my lawn tractor. I pulled the tank - not an easy job in a '27 touring car, and took it to a excellent radiator shop in Framingham, MA. They cleaned the tank and put some kind of coating on it's inside. I have had no fuel system problems since. I'm not sure what the OP meant when he said the full tank" overwhelmed" the float; the car should run just fine with a full tank. If the carburetor was seriously leaking gas, the odds are that the float didn't or there is crud at the needle and seat.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Aug 03, 2025 5:03 pm
I took the car to a show today and it ran fine with the new needle. As the oldest car there they asked me to park it next to the fire department’s restored 1923 fire engine.
Last edited by Reno Speedster on Sun Aug 03, 2025 7:01 pm, edited 1 time in total.
WillyR
First Name: Vilhelm
Post by WillyR » Sun Aug 03, 2025 5:16 pm
With simple cars it’s always the simple things.
fireheadman
First Name: Ben
Last Name: Piraro
* REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Post by fireheadman » Fri Sep 05, 2025 2:39 pm
was searching the forum for freeze plugs and read this article... that is a pretty neat idea.
wonder how well this has worked from when it was done?
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
https://www.youtube.com/watch?v=e5FPWnxG_9w
Post by Steve Jelf » Fri Sep 05, 2025 4:30 pm
...wonder how well this has worked from when it was done?
Worked OK for me, but it hasn't been 100 years yet.
