Some reassembly required
Topic author - Posts: 7395
Now I have to get it put back together.
Steve Hughes
- Last Name: Hughes
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Re: Some reassembly required
Nothing like the incentive program. I have confidence you can do it.
Joe Reid
- First Name: Joe
- Last Name: Reid
Did you rebuild your engine? Are you driving your 15 or your 23?
It will be the 15 again. The engine is at Mike's in Tulsa, and I'll be going down Monday for another work day. I hope to have it back in the car in a couple of weeks so I can spend August breaking it in and getting ready to go.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
I'm curious on how well the scat crank will work for you.
Gonenorth
- Last Name: Whelihan
- Board Member Since: 2008
Steve, you will love the SCAT crank. Engine runs smoother and no more worries about participating in the two-piece lottery.
Joe Reid
- First Name: Joe
- Last Name: Reid
Steve, are you coming up to the Iola Car Show? Sounds good about your 15.
Hmmm... That's week after next. I hadn't thought about it, but maybe I should head up that way and get out of the heat for a few days.
Beware on the Scat crank. The front horseshoe bolt comes too close to it, and I think I had to dish the horse shoe a bit too.
modeltbarn
- First Name: Gary
- Last Name: London
It's the rear hose shoe, not the front one...... there's lots of clearance for the front one, I finished my engine up the other day and went through that. Just use a 1" long 5/16" bolt, cut the head off, put it in the center rear horseshoe hole, weld it, then grind the horseshoe as needed. I'ts really easy to see this with the inspection pan off.
With Mike working on your engine he'll take care of it for you.
Yep, I believe he already did. Last session we got as far as trying to install the main shaft without any runout. When we couldn't do any better than .002" we quit that and did the front axle instead. I'm going back tomorrow with a box of main shafts in case we want to look for a better one.
