axle torque
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
axle torque
Post by Will » Tue Jul 29, 2025 10:35 am
On a 19 what should the axle torque be?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Last Name: Strange
Re: axle torque
Post by CudaMan » Tue Jul 29, 2025 11:37 am
If you're talking about the rear wheel retaining nut, I torque mine to 75 foot-pounds, then tighter as needed to get the cotter pin hole to line up with one of the windows in the castle nut. :)
jab35
Last Name: Bartsch
Re: axle torque
Post by jab35 » Tue Jul 29, 2025 11:39 am
Will: As in Engine Torque delivered to each rear wheel? As in rear Hub nut Torque to secure wheel to axle?
Will
First Name: Will
Last Name: Copeland
Re: axle torque
Post by Will » Tue Jul 29, 2025 11:49 am
Sorry, The garage is getting a bit to warm and I guess I'm not thinking clearly. Time to call it a day. , Yes I did mean the axle nut torque. Its already 97 degrees outside and even though I do have a single air conditioning vent in the garage it just cant keep up with the outside air coming in through outside edges of the garage door. I will finish this tomorrow morning.
Re: axle torque
Post by Mark Gregush » Tue Jul 29, 2025 11:53 am
I go a little higher, 90 then to next slot to line up the hole. Never back off on a cottered nut. Check a couple of times after that after the car has been driven. More often than not you will need to re-torque the nut.
If the next slot is way off, try a different nut or sand a bit off the bottom. Sandpaper on a flat surface works great.
Re: axle torque
Post by TXGOAT2 » Tue Jul 29, 2025 11:57 am
Humidity as well as heat makes the A/C work harder, so you are dealing with extreme conditions. You might consider improving the garage door and adding a window unit type A/C to the garage area for use only when you are working in the garage.
Re: axle torque
Post by TXGOAT2 » Tue Jul 29, 2025 11:59 am
Didn't Ford offer dealers a special axle nut wrench about 2 feet long? I'd guess that would translate to about 100 ft lbs.
Re: axle torque
Post by RajoRacer » Tue Jul 29, 2025 12:27 pm
Yes, they did - I can post a photo later today - mine was nickel plated as are some of my other "factory" wrenches.
Will
First Name: Will
Last Name: Copeland
Re: axle torque
Post by Will » Tue Jul 29, 2025 1:37 pm
AndyClary
First Name: Andrew
Last Name: Clary
Re: axle torque
Post by AndyClary » Tue Jul 29, 2025 3:57 pm
I agree with Mar on the 75# torque. I recheck after a short drive, especially if you are using shims. Axle nuts should also be part of your spring checkup or before a long tour like a national tour.
Andy
Will
First Name: Will
Last Name: Copeland
Re: axle torque
Post by Will » Tue Jul 29, 2025 5:36 pm
Thanks guys, I will take them to 75 tomorrow morning. It seems I'm driving it more this summer than I used to. There is a group of us that go to assisted living centers around my county to give car shows for those that cant get out. Used to be we only did this in the winter but the phone has been ringing off the hook for us to come. I'm the oldest car that goes, The others are 40'50'60' and 70 area cars. Its a little rough in this crazy heat but once I get there I spend most of my time inside. Last week I got caught in a rain shower and I had a heck of a time drying out the ignition so she would run right. I think I'm going to cover the hood with something on the next show. Down here you never know if your going to get wet. A shower can pop up out of nowhere.
Re: axle torque
Post by RajoRacer » Tue Jul 29, 2025 7:32 pm
For your viewing pleasure - it's approx. 20" in length.
Re: axle torque
Post by Allan » Tue Jul 29, 2025 7:46 pm
The torque on the axle nut is only part of the mix. It is probably more important to make sure that the axle taper is free of any damage and burrs. Likewise the bore in the hub. Then if the key is snug in the keyway, you are set to go. When the axle nut is drawn up it then has the best chance of maintaining "drive" on the taper and key. Applying excessive tension on the nut to make a poor taper assembly hold is a recipe for a stripped axle thread.
JohnH
Last Name: Hunter
Board Member Since: 2002
Re: axle torque
Post by JohnH » Tue Jul 29, 2025 9:34 pm
I would agree with that. The axle/hub taper, if not perfectly matched, will result in further wear, and possibly a crystalised and broken axle. Furthermore, it is undesirable that the drive should be transmitted through the Woodruff key. A good fit between the hub and axle will be such that it's possible to drive the car without the Woodruff key in position, and there will be quite some resistance in removing the hub from the axle. A hub which comes off without having to use a wheel puller is a worry. And definitely no shims. To answer the question, I tighten to 100 ft. lbs.
Re: axle torque
Post by speedytinc » Tue Jul 29, 2025 11:30 pm
A better answer might be to lap the axle & wheel hub.
Re: axle torque
Post by Jerry VanOoteghem » Wed Jul 30, 2025 6:30 am
... it is undesirable that the drive should be transmitted through the Woodruff key. A good fit between the hub and axle will be such that it's possible to drive the car without the Woodruff key in position...
FWIW, that's not a woodruff key. ;)
Will
First Name: Will
Last Name: Copeland
Re: axle torque
Post by Will » Wed Jul 30, 2025 6:50 am
Steve, I like your display. Some day when I move back north I'm hoping to have a larger garage and I want to set up a board like yours with all my specialized Ford tools. Thank again everyone for your help.
Re: axle torque
Post by TXGOAT2 » Wed Jul 30, 2025 7:51 am
20" wrench, 165 lb mechanic....
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: axle torque
Post by Erik Johnson » Wed Jul 30, 2025 8:39 am
I'm surprised that the rear axle nut "Z" wrench is open-end.
My father has a TT rear axle nut Z wrench and it is box-end. It also has a round handle which is easier on the hands.
Re: axle torque
Post by RajoRacer » Wed Jul 30, 2025 10:37 am
Thanks Erik - I'll go check the numbers - that could be the rear perch nut - I have more !
Re: axle torque
Post by Mark Gregush » Wed Jul 30, 2025 11:34 am
The main bolts are about 80 foot pounds and they are a lot smaller than the axle threads. 75# in my opinion is too little.
