Easy way to install valve split keepers?
Anton Seelmann
First Name: Anton
Last Name: Seelmann
* REQUIRED* Type and Year of Model Ts owned: Touring 19; Speedster 13/Rajo; Pickup 21; Tudor 25; Touring 25/Fronti; Touring 1909
Post by Anton Seelmann » Mon Aug 04, 2025 3:01 pm
How do I install the split keepers when the engine is in the car and the intake and exhaust manifolds are mounted on the engine?
I use a compressor tool for the spring - see photo.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Easy way to install valve split keepers?
Post by Rich P. Bingham » Mon Aug 04, 2025 3:56 pm
Sounds like difficulty level 5 :lol:
“Glue” the keeper halves in place with a dab of heavy grease.
Get a horse !
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Aug 04, 2025 6:33 pm
Pull the intake off.
Last Name: Hatch
Post by Dan Hatch » Mon Aug 04, 2025 6:53 pm
There are tools made to do that.
Post by Allan » Mon Aug 04, 2025 8:14 pm
You do need a valve lifter which lifts in parallel. Otherwise the keeper and spring will be cocked and the two collets cannot be fitted. With the springs truly compressed, "glue" the collets to the valve stems with the suggested heavy grease. Taking the inlet manifold off makes it much easier.
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Tue Aug 05, 2025 2:00 am
I use "Assemlee Goo" its used for putting automatic transmissions together. Just a little dab with a screw driver on the valve stems and
the keepers stay put. You can push them around with your fingers and they still stay put. It makes the job go twice as fast as you arent't chasing
the keepres that would keep falling off.....
Anton Seelmann
First Name: Anton
Last Name: Seelmann
Post by Anton Seelmann » Tue Aug 05, 2025 3:05 am
Thanks everyone.
I should have known about the "glue" thing myself.
I ordered Assembllee Goo green.
Have a nice week and hopefully better weather than here in Bavaria.
Anton
