rear end bearing sleeves
Topic author - Posts: 379
- First Name: Colin
- Last Name: Mavins
I have found in Dads garage nos bearing sleeves , I am guessing they are soft as apposed to the hardened sleeves for sale by vendor. Should I buy hardened sleeves or use the Nos sleeves. Back in Dads day you would use inner sleeves from another diff and use them as outer sleeves to complete your rebuild. Thanks in advance for your wisdom Cheers Colin
Re: rear end bearing sleeves
Use them. Better to wear the sleeves than the original hyatts.
Are the sleeves marked "Ford" or "Hyatt"? If so, definitely use them.
- Last Name: Jablonski
Dad had a good idea... And as long as you have two lefts and two rights on those NOS Sleeves, you're set.
- First Name: DAN
- Last Name: MCEACHERN
there was some repro junk out there in years past do be cautious!
- First Name: Colin
- Last Name: Mavins
They are marked Hyatt, I am building a spare diff and while cleaning out the garage I have found all nos part ect the cast carrier and the housings.
