exhaust pack nut dimension
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Sun Aug 10, 2025 7:19 pm
Could someone please tell what size wrench is used on the exhaust pipe pack nut ?
Thank you
Johnr
Re: exhaust pack nut dimension
Post by DanTreace » Sun Aug 10, 2025 8:00 pm
Appropriately 2 1/16” - 2 1/8” opening on Ford pack nut wrench.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sun Aug 10, 2025 8:02 pm
Vern (Vieux Carre)
Post by Allan » Sun Aug 10, 2025 11:11 pm
An 18" Bahco [crescent] adjustable wrench works fine for me.
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Mon Aug 11, 2025 9:26 am
The Ford issued exhaust nut wrench measures 2.043".
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Line_Noise
First Name: Derek
Last Name: Dudgeon
Board Member Since: 2022
Post by Line_Noise » Mon Aug 11, 2025 11:12 am
If you have a reproduction pack nut, the factory wrench may not fit. I've run across several of the reproductions that were at least a 1/16" oversize, the ones that are more simply machined without bevelled corners tend to be the worst.
Post by Allan » Mon Aug 11, 2025 7:32 pm
The big shifter fits all variations.
