Original New Day Brush
Post by Original Smith » Tue Aug 12, 2025 12:40 pm
I'm not good at pictures, but this is the best I can do for now. If needed, I can try again.
ND 3.JPG (18.84 KiB) Viewed 757 times
ND 2.JPG (21.16 KiB) Viewed 757 times
Re: Original New Day Brush
Post by Original Smith » Tue Aug 12, 2025 12:45 pm
Please note the brush holder is copper plated, and the actual brush is smaller than the Tip Tops.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Tue Aug 12, 2025 1:56 pm
Pictures of NOS brush and timer.
Post by RajoRacer » Tue Aug 12, 2025 2:00 pm
Thanks Kim - saved me a trip out to the shop with my camera !
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Tue Aug 12, 2025 2:16 pm
This copper plated new day brush holder uses the wide brush.
Scott C.
Last Name: Clements
Post by Scott C. » Wed Aug 13, 2025 10:20 am
Thanks for the pictures!
Post by Original Smith » Wed Aug 13, 2025 1:28 pm
The example of the copper plated wide brush holder isn't copper plated at all! It is solid copper and was probably made by the former owner. I have yet to see an original New Day brush that used the wide style as used today.
Post by speedytinc » Wed Aug 13, 2025 1:41 pm
I have several also, wide, solid copper. They were not one off made.
They came in one of the new day copy type timers.
As I recall, timing is even further off from a ford roller timer.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Wed Aug 13, 2025 4:27 pm
This is a spare that I have, it is identical to the NOS one that I put into my new rebuild as you can see it is magnetic. Along side of it is a couple of brushes that I made from an old motor brush like the one behind. Jim
