Body to Chassis Pads
Campbell Tellman
First Name: Campbell
Last Name: Tellman
* REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
Post by Campbell Tellman » Thu Aug 14, 2025 1:53 pm
Hey All,
After removing the body to repair it I now cannot remember where the pads go. I have new dust shields and I don't see much info in the Ford Service Manual.
Can anyone advise me?
Thanks,
Campbell Tellman II
1916 Ford Touring Car
Beaufort, NC
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Body to Chassis Pads
Post by Erik Johnson » Thu Aug 14, 2025 2:15 pm
When your 1916 touring originally came from the factory, there were no pads between the body brackets and the chassis.
If there were pads when you removed the body from the frame, those would have been added by someone at a later date.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Thu Aug 14, 2025 2:54 pm
You may have had shims to adjust door openings.
John_Aldrich
Last Name: Aldrich
* REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Post by John_Aldrich » Fri Aug 15, 2025 12:23 pm
I used an old inner tube that I cut up and used between the body brackets and the frame on my 1915. No noise at all...
John Aldrich
Typical Model T Addict
Post by TRDxB2 » Fri Aug 15, 2025 1:17 pm
Hot rodders use them to reduce vibrations. Old tubes work too
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Fri Aug 15, 2025 2:19 pm
You can also use these to make your own:
https://www.homedepot.com/p/Everbilt-4- ... -n/a-_-n/a
Campbell Tellman
Last Name: Tellman
Post by Campbell Tellman » Fri Aug 15, 2025 3:14 pm
Thanks to all that responded. I looked at the pads today and they are about 1/2 inch thick rubber. There is a longer pad under the radiator. I have done a lot of work on the body and the doors are perfect. I will check the frame rails to see if I need the pads to keep the body level.
Campbell Tellman II
1916 Ford Touring
Beaufort, NC
Post by Allan » Fri Aug 15, 2025 8:53 pm
Introducing a 1/2" pad under the body would necessitate raising the radiator too so the hood would still fit. !/2" is overkill. If the aim was to stop noise/squeaks 1/8" would do. Best to use insertion rubber with the fabric in the rubber That said the only place I have ever used any rubber is under the pan ears on just one of my Ts.
As others indicated, sometimes shims are used on the frame mounts to adjust door gaps. The need to do so indicates the frame is no longer straight.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Aug 15, 2025 10:40 pm
I would skip installing rubber pads or shims.
