Support Forum
csnailnrun
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Post
by csnailnrun » Sun Jun 30, 2019 9:05 pm
My '12 radiator needs a good core cleaning... It's too hot too quick
What recommendations do y'all have?
Thank you!
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Sun Jun 30, 2019 10:32 pm
I had pretty good luck with CLR.
I would avoid getting it on the brass.
gelfling
- Last Name: Gelfer
- * REQUIRED* Type and Year of Model Ts owned: 1912 roadster
Post
by gelfling » Sun Jun 30, 2019 10:41 pm
If the fins are not tightly bonded to the tubes, cleaning will not help you much. This happens with antique radiators. If cleaning doesn't improve the situation, you will have to either re-core it or buy a new radiator. I think that old radiators are the biggest reason why people can't drive their Ts more than a few miles without overheating.
Les Schubert
- First Name: Les
- Last Name: Schubert
Post
by Les Schubert » Sun Jun 30, 2019 11:25 pm
Plain vinegar works well and doesn’t cause any damage
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Post
by Erik Johnson » Sun Jun 30, 2019 11:32 pm
Other causes of overheating worth mentioning:
- not enough oil in crankcase
- fuel mixture too lean
- retarded ignition timing
- poor driving technique
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Post
by George N Lake Ozark » Mon Jul 01, 2019 2:27 am
I've used Cascade dishwasher soap to degrease, Flush with water then an overbite soak with CLR . Rinsed with baking soda to neutralize.s it would also work if very careful not to spill on exterior Rinse again and fill with coolant of your choice. I haven't done this on an all brass radiator. Guess it would also work if careful not to spill on exterior.
George N Lake Ozark
Post
by George N Lake Ozark » Mon Jul 01, 2019 2:29 am
Also check what Erik said
thom
- First Name: Tommy
- Last Name: Coffey
Post
by thom » Mon Jul 01, 2019 8:27 am
CLR labels now say not recommended for radiators. Must be a reason.
Post
by TWrenn » Mon Jul 01, 2019 9:19 am
My best luck, and best advice to cure an overheating 100+ year old radiator was, and is, to get a NEW one!
Been there, done that. 4 vehicles worth, out of 6!! Not too bad an average eh??
Scott C.
- Last Name: Clements
Post
by Scott C. » Mon Jul 01, 2019 11:35 am
I tried all sorts of things on my 26, vinegar, Dawn dish soap, Purple Power, Simple Green, Macs radiator cleaner, after multiple times each, none of them did the trick. Then I bought a bottle of Thermocure. It is a radiator cleaner that is made by Evaporust. It did a very good job. I have since used it on another radiator and again, it did a very good job. I did have to due it a few times. I reused it a couple of times, then used a fresh bottle. The radiators came out very clean and they cool fine. I picked it up at Walmart for about $20 a bottle.
Lutz T Guy
- First Name: Phillip
- Last Name: Maurici
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring, 1917 runabout, 1917 Touring, 1927 Touring
Post
by Lutz T Guy » Mon Jul 01, 2019 1:41 pm
Put a box of Arm and Hammer which is dissolved in water in. Run it that way for about 50 miles and grand and flush. This a old trick my dad used on his trucks.
Post
by Scott_Conger » Mon Jul 01, 2019 4:46 pm
Phil
my guess is that he used Arm and Hammer Washing Soda...most on this forum would guess Baking Soda which is a good acid neutralizer, but not so good on radiators
csnailnrun
- First Name: Ryan
Post
by csnailnrun » Mon Jul 01, 2019 9:47 pm
Thanks for all the suggestions y'all. I had it off while I put a new cam and reset the valves. There was a bit of 'gunk' sitting in the bottom of the lower spout. I suspect the cores are quite dirty.
