Spotlight Wiring
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Spotlight Wiring
Post by CatGuy » Fri Aug 15, 2025 4:56 pm
I'm going to mount a spotlight to the windshield of my '26. Where is the best place place to connect the wire?
Last Name: Humble
Board Member Since: 2006
Re: Spotlight Wiring
Post by Humblej » Fri Aug 15, 2025 5:35 pm
You could run a wire to the tail light connection on the firewall terminal block and it will only work when the lights are on, or to the battery connection on the terminal block if you want it to work all the time.
Post by TRDxB2 » Fri Aug 15, 2025 6:03 pm
Did you drive the T to your new home yet. Is the spotlight required now :P
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Aug 15, 2025 7:02 pm
It would be best to include an on-off switch if it doesn't already have one. Mine had a twist switch built into the connector on the rear of the light.
CatGuy
Last Name: Hunt
Post by CatGuy » Mon Aug 18, 2025 8:34 am
Not yet. That's on the 29th. The longest drive for the T in many years and the longest I've ever driven one!
Post by Jerry VanOoteghem » Mon Aug 18, 2025 12:01 pm
I would wire it from the battery lead, (the thick yellow wire), with a switch placed in-line. That way, it can be used at any time, whether or not the car is running or if the headlights lights are turned on.
