Fan belt won't stay on the pulley
Last Name: Hjortnaes
Post by DHort » Fri Aug 15, 2025 2:01 pm
One of our members was having issues keeping the fan belt on the pulley. I used an old trick of turning it around. Now it stays where it belongs.
Cheap fix to a frustrating problem. I forgot who told me KISS just might solve your problem.
I forget the technical reason why this works. Some sort of flaw in the manufacturing process
that makes one side of the belt tighter or smaller than the other side.
Re: Fan belt won't stay on the pulley
Post by Allan » Fri Aug 15, 2025 9:13 pm
Mis-aligned pulleys can stretch one side of a flat fan belt, rather than it being a manufacturing fault. This happens more often on the cars with the longer fan arm. The remedy is to check and possibly reset the fan arm so the fan shaft is parallel to the crankshaft.
Post by Jerry VanOoteghem » Mon Aug 18, 2025 12:11 pm
100% ^^^
Post by TXGOAT2 » Mon Aug 18, 2025 12:51 pm
It's difficult to keep a belt on misaligned pulleys or pulleys with the crown worn flat.
