I recently finished the build of a 1926 Model T Speedster with an oval gas tank. I would like to add the appropriate Ford decal for the period on the sides of the gas tank but cannot seem to find a place to purchase them, even though I have seen many gas tanks with the decal/vinyl on the side. Any idea where to purchase them decals?
[image][/image]
Ford decal for side of speedster gas tank.
Re: Ford decal for side of speedster gas tank.
Ebay has a bunch !
Topic author - Posts: 2
- First Name: Ernie
- Last Name: Mee
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1926 Speedster
Thanks, I will give it a try again.
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
Any local vinyl graphics shop or sign shop should be able to print up one for a reasonable price if you can’t find what you are looking for.
If you are using a standard T oval tank, most I have seen have a depressed X pattern in the ends. A vinyl stick-on may not be the answer. A vehicle wrap type application should do the trick. Maybe neither will appreciate fuel being spilled over them.
Allan from down under
