Ford decal for side of speedster gas tank.
Meestro
First Name: Ernie
Last Name: Mee
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1926 Speedster
Post by Meestro » Mon Aug 18, 2025 1:52 pm
I recently finished the build of a 1926 Model T Speedster with an oval gas tank. I would like to add the appropriate Ford decal for the period on the sides of the gas tank but cannot seem to find a place to purchase them, even though I have seen many gas tanks with the decal/vinyl on the side. Any idea where to purchase them decals?
[image][/image]
Re: Ford decal for side of speedster gas tank.
Post by RajoRacer » Mon Aug 18, 2025 2:54 pm
Ebay has a bunch !
Meestro
First Name: Ernie
Last Name: Mee
Post by Meestro » Mon Aug 18, 2025 4:03 pm
Thanks, I will give it a try again.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Mon Aug 18, 2025 6:39 pm
Any local vinyl graphics shop or sign shop should be able to print up one for a reasonable price if you can’t find what you are looking for.
Post by Allan » Mon Aug 18, 2025 8:00 pm
If you are using a standard T oval tank, most I have seen have a depressed X pattern in the ends. A vinyl stick-on may not be the answer. A vehicle wrap type application should do the trick. Maybe neither will appreciate fuel being spilled over them.
Allan from down under
