Sediment bowl/bulb vs modern fuel filter
fireheadman
First Name: Ben
Last Name: Piraro
* REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Post by fireheadman » Fri Aug 22, 2025 3:11 pm
I posted on this in my build thread, but wanted to do something seperate.
I currently have nothing aside from a ball valve under my tank. I would like to put something to help filter impurities to the carb/engine.
I do like the possibilty of putting a sediment bowl/bulb in place of the ball valve, this would only use the brass screen to catch things. But it looks like the connection on those are 1/2" NPT or Straight (needs packing nut/felt) ?
And if I went the route of a modern fuel filter, some have mentioned the issue of flow issues from being gravity fed?
What is the most common solution to filtering fuel?
Or am I over thinking this issue (as I usually do).....
Here is my current tank connection:
This is a sediment bowl/bulb I have seen on eBay or parts dealers -- the input threads look to be 1/2 NPT|Straight
And this is the Napa 3032 inline filter
There is also maybe the option of a glass bowl filter?
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
https://www.youtube.com/watch?v=e5FPWnxG_9w
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: Sediment bowl/bulb vs modern fuel filter
Post by mtntee20 » Fri Aug 22, 2025 4:07 pm
Ben,
It is ALL up to YOU to make the best decision for your truck. Since you're asking for experience of others, I would recommend listening to Ron. He KNOWS what he's talking about. What he recommends, has worked extremely well for him, and others, for many years.
A man/woman can gain experience by doing it themselves OR by listening to a good Teacher.
Good Luck
fireheadman
First Name: Ben
Last Name: Piraro
Post by fireheadman » Fri Aug 22, 2025 4:13 pm
I do not disagree with you or Ron at all.
I just learned to always include a broader audience from time to time.
There are times when all you know is what is "right" because that is what you learned to be true (that isn't right or wrong) and then there are times when new things come up that you may not be aware of. I like knowing as much as possible to make an educated decision.
So that is why I created the thread. I'm curious what others are doing and why.
Post by RajoRacer » Fri Aug 22, 2025 4:20 pm
I prefer to keep my Ts mostly stock especially the fuel delivery system although I do install a shut-off at the carburetor. The repro sediment bulbs have a decent track record - I've installed quite a few. I also use annealed 1/4" steel brake line to make my own fuel line & use neoprene gaskets. It's quite a simple solution but ditch the inline filter !
Post by Steve Jelf » Fri Aug 22, 2025 5:53 pm
Modern inline filters usually mean trouble in the Model T gravity-feed system. I fought trashy fuel for a long time until a loose baffle flopping around inside caused me to buy a new tank. The old tank took the trash with it and I never had the problem of trashy gas again because I was very careful to avoid contamination when refilling.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Aug 22, 2025 6:11 pm
When my Dad and I restored my grandfather's 27 coupe, with cowl mounted tank, back in the 1960's, I can't remember whether we had the original sediment bulb/filter, or not, but we chose to replace it with a modern glass bowl bulb with brass filter screen and built in shut off. I worked fine and stayed that way until this millennium when I went back to the original when doing a updated restoration.
Post by speedytinc » Fri Aug 22, 2025 6:41 pm
Under seat vs cowl tank is apples & bananas. I would not be surprised an inline filter worked on a cowl tank.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Fri Aug 22, 2025 6:48 pm
Hi Ben,
Looking at the photo that you posted of your gas tank connection, it raises a few questions. It appears that the tank outlet is too small for the stock sediment bowl. It also appears that the tank outlet is almost directly above the exhaust pipe. I would not expect to find either if it was a stock Ford gas tank. If these things are true, and your vehicle has an aftermarket/re-purposed/non-stock gas tank, then your options point towards a one-off solution. A separate glass bowl sediment filter (without the internal pleated filter element) can replicate what the Ford "potato" does. You would need to source one, I would look towards vintage tractor parts suppliers. Once found, you would then need to figure out a good place to mount it. Since this would be a completely custom installation, the advice here will probably be limited to general considerations.
Some folks run electric fuel pumps if their fuel tank is located somewhere that a gravity feed is less effective. With a fuel pump, a modern fuel filter cartridge becomes more viable. Typically, adding a pressure regulator is a good idea with a fuel pump, to get the fuel pressure down to the <2 psi that the stock Ford carburetors are comfortable with.
Alternatively, installing a reproduction Ford gas tank would mean that you could use more stock parts and get more specific advice on getting things back to "spec".
Keep crankin',
Eric
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Aug 22, 2025 7:49 pm
That looks like a natural gas/manufactured gas pilot light valve.
The 1953 Rheem furnace that was original to my house had a "B" handle valve for the pilot light, but the inlet and outlet were in straight line, not 90 degrees like yours. It was a tapered valve, not a ball valve, with a tension spring and screw on the opposite side from the B handle.
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Aug 22, 2025 8:03 pm
The new repro bulbs seem to work fine. If thread size is an issue, you can use a pipe thread reducer. I went to a tractor sediment bowl with a fine mesh screen. No filter element. Some of these tractor bowls have a built in fuel shut off. Similar to
Fuel filter bowl screen type.JPG (14.05 KiB) Viewed 3246 times
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Fri Aug 22, 2025 8:28 pm
Don’t use an automotive type in line filter. What I’ve always used on my T’s is a lawnmower in line filter. Most of them are gravity feed like the T. It’s not the same as a pump type auto fuel system. Never had a problem using them.
Post by Original Smith » Sat Aug 23, 2025 12:16 pm
It depends how authentic you want to be. I appears the flange for the gas tank has been removed. Maybe you should find a good used gas tank, or buy a new one. Don't assume a used sediment bulb will be useable right off either. Most of them have a hole punched through the screen. When I did my '25 It took 5 sediment bulbs before I found a good one. and lots of cleaning with carburetor cleaner, scratch awls and lot's of blowing backward to get all the junk from within.
fireheadman
First Name: Ben
Last Name: Piraro
Post by fireheadman » Sat Aug 23, 2025 3:45 pm
was up til 2:30a (from last night) installing the new wiring harnesses and undoing my grandfathers hot-wiring job.... what a mess that was!
while I was underneath the "T" I got a couple drops of fuel on my forehead, so started inspecting the tank.
...Looks like he also tinkered with that too. It definitely needs to be replaced. There was a plate welded the bottom, which is why it looks so different. Some of those welds are corroding and starting to leak fuel.
I'll look out for an oval tank, then I should be back on track for that part of the vehicle.
Its amazing for the amount of tweaks done that were done to it back in the day to keep it on the road. Lots of ingenuity going on for sure! I plan on updating things like this as I find them.
Post by RajoRacer » Sat Aug 23, 2025 3:48 pm
Ben - word of caution: there's usually some reason/reasons that a used gas tank becomes available. New ones are available albeit pricey, but one less worry !
fireheadman
First Name: Ben
Last Name: Piraro
Post by fireheadman » Sat Aug 23, 2025 4:07 pm
NOS first for me, then lightly used as the next option.. I learned that before the hard way.
Last Name: Hatch
Post by Dan Hatch » Sat Aug 23, 2025 4:28 pm
Do your self a favor, buy a new tank. Used tanks are like used radiators. They are not on a car for a reason.
Post by Original Smith » Sat Aug 23, 2025 5:21 pm
I bought a NOS oval tank at Chickasha. I put it on my car and used it quite a while until the flange developed a leak, and I had to take it to a radiator shop to get repaired. In the meantime I put on a nice used tank, which is still on the car. I didn't feel like going through all that trouble again! The NOS tank is still waiting for the day when it can be of service again.
erkbrn
First Name: Eric
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
Post by erkbrn » Sat Aug 23, 2025 7:04 pm
My speedster has a tank that sits up on a "shelf" behind the driver, much like many speedsters. There isn't much clearance under the tank, and no room for a sediment bulb. I wanted there to be some kind of screen/filter and a paper one (which I removed from the car previously) caused flow problems. Ended up fashioning a custom screen from one of the Model A screens (available at vendors) and a spare brass NPT adapter (which I believe was 1/4" NPT female to 1/4" NPT male). I brazed the Model A screen onto the male end of the adapter carefully such that it would still thread into the tank. A little loctite fuel sealant and it's been perfect. This may not be super helpful to you given the looks of the connection on your tank, but might give you an idea. Also a good option for those with a standard tank.
fireheadman
First Name: Ben
Last Name: Piraro
Post by fireheadman » Sun Aug 24, 2025 11:03 am
I've come across a filter that looks like what you posted... it would work, but if you ended up with some trash/sediment in the tank there would be no way to drain it out easily right?... at least not something as easy as turning a petcock valve or removing a bowl.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sun Aug 24, 2025 12:47 pm
It’s tough to beat the design of the Ford sediment bowl. It gives you the ability to shut the fuel off, filter out dirt, drain any water or sediment, and drain the tank all in one.
mtntee20
Last Name: Miller
Post by mtntee20 » Sun Aug 24, 2025 2:16 pm
AND they leak. Some more, some less.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Aug 24, 2025 3:12 pm
Presuming you’re referring to the original Ford sediment bulb ? Mine does not.
Requisite is a sediment bulb in good enough condition that the valve can be “lapped” to a proper fit. Assemble the parts with an application of that heavy, pasty fuel valve lubricant, which will also keep the valve cone from sticking in the body. In my experience there’s no substitute for the original lead washer to seal the fuel line outlet in the “spud”. Treat the drain petcock the same way, of course.
Get a horse !
John Codman
Last Name: Codman
Post by John Codman » Mon Aug 25, 2025 2:25 pm
I couldn't agree more. If your tank was in good condition, I would remove it and take it to a radiator/tank shop and have it "sloshed", then coated with a chemical/paint that will keep things from recurring. I did that to my '27. If your existing tank isn't in decent shape, then I would follow Dan's advice. There is such a thing as false economy.
I also would not use the in-line modern car fuel filters. They are designed for a pressurized fuel system. I'm not saying that it will not work, but it will have greater restriction then the sediment bowl.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Mon Aug 25, 2025 6:37 pm
It USUALLY DOESN’T work… You initially run out of gas with right around 3-5 gallons remaining. And it gradually gets worse.
Post by speedytinc » Mon Aug 25, 2025 6:52 pm
Of course, I defer to those with the experience. There is so much more head pressure with the cowl tank, Ford used a larger float.
Post by TXGOAT2 » Mon Aug 25, 2025 9:30 pm
In some cases, the pleated paper filters can become restricted from traces of moisture in the fuel even when there is no dirt present. It's not uncommon for ethanol gas to be slightly hydrated, and any gasoline can absorb a very small amount of moisture. The paper element will trap and hold the moisture, which makes it less permeable to gasoline. This can happen when no free water is present.
Post by Original Smith » Tue Aug 26, 2025 1:01 pm
I prefer buying from Lang's, but they don't carry the lead sediment bulb gaskets any more, so I had to get one from Snyders.
AZTerry
First Name: Terry
Last Name: Loftus
* REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Post by AZTerry » Tue Aug 26, 2025 6:34 pm
The only external in line fuel filter I have had excellent luck with is the Mr. Gasket Clearview filter. It is not a paper filter so no or very little restriction. They are available for 1/4, 5/16, and 3/8 fuel line. It is a clear glass filter so you can see if there is crud in the filter. You can also take it apart to clean it or replace the filter element. I believe there are now knock offs of this filter as well. Link to show you the basic filter:
https://www.google.com/search?client=fi ... uel+filter
I also use VW fuel filter screens inside the tank. If interested in how I do it leave a comment and I can post explanation as well as photos.
Terry
erkbrn
First Name: Eric
Last Name: Brown
Post by erkbrn » Sun Aug 31, 2025 9:17 pm
True, it’s a little more effort. Sediment would collect around the neck of the filter screen and just sit at the bottom of the tank. Cleaning it out means draining the tank and removing the fitting. The loctite sealant isn’t permanent so that’s not a huge issue. Fortunately the gas here seems pretty clean and I’ve seen very little for the past two years since the screen has been installed.
Post by Original Smith » Tue Sep 02, 2025 12:16 pm
I have mine off now, and the tank is going to the local radiator shop to get the flange re-soldered. I've been told the lead gasket for the sediment bulb is inferior, but I disagree. Ford made 14 million cars with the early style sediment bulb. I'll stick with the Ford method! BTW, Snyder's still carries that lead gasket.
