Door glass installation questions.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Wed Aug 20, 2025 8:03 am
I'm installing the glass windows in a 26-7 Coupe.
Question 1: First three photos...the lower glass channel is physically too long to fit. My original shows glass protruding past the channel. How long should it be?
window channel 01.jpg (34.22 KiB) Viewed 1475 times
Question 2: Photo 4...the knob on the reproduction regulator does not spin. Is it supposed to roll or merely slide?
window channel 05.jpg (17.1 KiB) Viewed 1475 times
Question 3: Photo 5...the channel for the "roller" (not the channel for the glass) does not extend all the way to support the knob when lowered. When I shorten the channel, should I cut all the excess from the A-pillar side?
Vern (Vieux Carre)
varmint
First Name: Vernon
Last Name: Worley
Re: Door glass installation questions.
Post by varmint » Sat Aug 23, 2025 8:19 am
I am not the expert. I remember one day in grade school that I asked my mom for help with math homework but this time when she looked at it, she was unable to explain it. I wasn't sad because i could not get help but because I felt pity for her. A few years later, I taught her the new math. Fifty years (and three days) have passed and I have the same feeling again.
From what I can tell from the remnant of the glass in the channel, the glass extends 5/8" passed the end where the glass interacts with the fuzzies. So, both sides combine to 5/4". Original glass is cut to 25-1/2" wide at the base. However our laminate is cut to 25-1/4" to fit the reproduction fuzzies. It follows that the channel should be cut to 24" even. 24" does indeed fit between the front and rear fuzzies without contact.
Answer to the 2nd question...does the roller roll...I don't care for now as it can be fixed later.
Last answer, #3. By moving the regulator to the lowest position, it is also closest to the A-pillar and rolling the window up until it is exactly horizontal, gives us the rear most position. In my case, cutting the excess completely from the A-pillar side on both driver and passenger doors, places the channel in support with the roller through out its travel.
It is installed.
Vern (Vieux Carre)
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Aug 23, 2025 9:56 am
While I can not answer all the questions due to a lack of information on exact details, I would have to study your exact situation for the best answer.
The repro parts are made more universal than original parts were made so sometimes light modification is required.
Fitting all the window parts in the door and making them work can be tricky sometimes.
Verify what is going on before modifying to make sure you don't ruin parts (and money).
I can answer question #2 (picture #4)
Having worked on several original, repro, and repaired ones I have never seen one that rolls.
The rollers were riveted solid to the arm and are supposed to slide in the channel, so add a dab of grease when finished assembling.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sat Aug 23, 2025 10:35 am
The brass roller is supposed to rotate. They do on my Centerdoor.
William L Vanderburg
1922 Center Door Sedan
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Aug 23, 2025 11:22 am
A lot of the reproduction parts for the 1926-27 coupe door are junk, however the model A 1928 closed pick-up truck is the same door and the Model A parts are top quality. Throw away those repo parts and start over with Model A parts.
Last Name: Seth
Post by perry kete » Sat Aug 23, 2025 11:33 am
I have a '22 Coupe and the brass roller turns freely along the track so I would guess that your roller should roll and not be in a fixed position. Sliding a solid metal piece against another solid metal piece would cause one to wear a flat spot or hole in the other.
