Where to buy Murphy Fasteners for Top Boot?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Tue Aug 26, 2025 1:59 pm
Can anyone point me in the right direction for the Murphy Fasteners for the sides of the Top Boot?
dr1960
First Name: David
Last Name: Ruedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Re: Where to buy Murphy Fasteners for Top Boot?
Post by dr1960 » Tue Aug 26, 2025 2:15 pm
Try Mike at Classtique Upholstery. https://www.classtiqueupholstery.com/index.php
David - Yukon, OK
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Tue Aug 26, 2025 2:20 pm
Hi James,
Murphy fasteners are also know as "common sense turn button" fasteners. There are many different versions from our regular T vendors, in both brass and nickel finishes.
Keep crankin',
Eric
WayneJ
Last Name: Jorgensen
Post by WayneJ » Tue Aug 26, 2025 4:42 pm
You can find them on Amazon.
Wayne Jorgensen, Batavia, IL
1918 Runabout
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Tue Aug 26, 2025 5:46 pm
Langs sells them...pg 198 in their 2021 catalog...don't know if there's a more recent one or not
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Aug 26, 2025 6:06 pm
Different years of cars used different styles.
What year of top boot?
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Tue Aug 26, 2025 6:43 pm
Russ Furstnow should have all the Murphy fasteners you could need.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Aug 26, 2025 6:47 pm
Restoration Supply
https://restorationstuff.com
Fozz71
Last Name: Chochole
Post by Fozz71 » Wed Aug 27, 2025 8:20 am
It is for a 1916 Touring, here's my confusion. It is fitting to the sides of the Top Boot so it is mounting directly to fabric. All the fasteners I see have two screw holes on the base and those attach to wood. Which ones work with two pieces of fabric only?
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Wed Aug 27, 2025 8:24 am
Try this link, if still not what you want but it should be, keep searching their site. They'll have it. No need to go looking
all over green earth lol
https://www.modeltford.com/item/MUR-BPL.aspx
Post by DanTreace » Wed Aug 27, 2025 8:28 am
This kind, male twist sandwich between fabric and it’s backing plate, compress the lugs to lock
Open portion to other fabric, with its backing plate.
Comes in government black or nickel or brass.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Aug 27, 2025 11:28 am
I believe the factory issued top boot for 1916 is the same as 1917 - no Murphy fasteners:
Refer to this thread:
https://www.mtfca.com/discus/messages/5 ... 1455820509
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Aug 28, 2025 4:31 pm
Ohio Travel Bag. They call them common sense fasteners.
Post by Original Smith » Fri Aug 29, 2025 1:58 pm
It all depends on how authentic you want to be. A real Murphy fastener usually has an M with a circle around it.
