Where to buy Murphy Fasteners for Top Boot?
Topic author - Posts: 275
- Last Name: Chochole
- Board Member Since: 2003
Can anyone point me in the right direction for the Murphy Fasteners for the sides of the Top Boot?
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Re: Where to buy Murphy Fasteners for Top Boot?
Try Mike at Classtique Upholstery. https://www.classtiqueupholstery.com/index.php
David - Yukon, OK
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Hi James,
Murphy fasteners are also know as "common sense turn button" fasteners. There are many different versions from our regular T vendors, in both brass and nickel finishes.
Keep crankin',
Eric
Keep crankin',
Eric
- Last Name: Jorgensen
- Board Member Since: 2013
You can find them on Amazon.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Langs sells them...pg 198 in their 2021 catalog...don't know if there's a more recent one or not
- First Name: Keith
- Last Name: Townsend
Different years of cars used different styles.
What year of top boot?
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Russ Furstnow should have all the Murphy fasteners you could need.
- First Name: DAN
- Last Name: MCEACHERN
It is for a 1916 Touring, here's my confusion. It is fitting to the sides of the Top Boot so it is mounting directly to fabric. All the fasteners I see have two screw holes on the base and those attach to wood. Which ones work with two pieces of fabric only?
- First Name: T
- Last Name: Gates
Try this link, if still not what you want but it should be, keep searching their site. They'll have it. No need to go looking
all over green earth lol
https://www.modeltford.com/item/MUR-BPL.aspx
This kind, male twist sandwich between fabric and it’s backing plate, compress the lugs to lock
Open portion to other fabric, with its backing plate.
Comes in government black or nickel or brass.
- First Name: Erik
- Last Name: Johnson
I believe the factory issued top boot for 1916 is the same as 1917 - no Murphy fasteners:
Refer to this thread:
https://www.mtfca.com/discus/messages/5 ... 1455820509
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Ohio Travel Bag. They call them common sense fasteners.
It all depends on how authentic you want to be. A real Murphy fastener usually has an M with a circle around it.
