Rear wheel seal mystery
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Wed Aug 27, 2025 10:07 am
I am not rebuilding my rear axle just yet, but I'm doing my springs, but I figured I'd look at the mess behind the wheels while there off and I found various felts and washers and it looks like there not correct. Both pictures are left to right in order left being closest to the bearing and right being the outer most, I thought it was just supposed to be felt then cup but I got felt washer felt cup and one had one felt outside one had both inside.
Edit: I noticed just now that my images are for whatever reason mirrored so it's right to left.
Last edited by LittleTimmy52 on Wed Aug 27, 2025 12:12 pm, edited 1 time in total.
Re: Rear wheel seal mystery
Post by RajoRacer » Wed Aug 27, 2025 10:13 am
Correct order is: 1 steel washer, 1 felt (sometimes too thick), then cup.
Post by Jerry VanOoteghem » Wed Aug 27, 2025 11:48 am
People sometimes also add a felt between the outside of the cup and the wheel hub. Not saying that's correct, just that some people do it.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Wed Aug 27, 2025 12:12 pm
Should I add the extra felt outside?
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Wed Aug 27, 2025 12:13 pm
Of its only one felt on the inside which is? The one with the bigger or smaller inner diameter?
Post by RajoRacer » Wed Aug 27, 2025 12:25 pm
Smaller - it fits tight over the axle. Ford did supply a felt seal for inside of the housings - most of us use the modern neoprene seals inboard of the sleeve.
jsaylor
Last Name: Saylor
Post by jsaylor » Wed Aug 27, 2025 12:30 pm
The outside felt - There is a small recess in the hub which takes a thinner felt Langs part # 2809. It helps to keep dirt and road debris out of the brake area.
Post by DanTreace » Wed Aug 27, 2025 1:41 pm
The earlier axle housing have a slightly smaller collar for the cap, part # 2510, nominal dia. 2 13/32". Used '09-''17.
After 1918 the later tad larger dia. cap is part #2510 1/2. This is the avail. cap from vendors.
So fitting a replacement cap one may have to use a shim on early axle housing collar
The use of the modern alum cap with the dual o-ring seals are made in styles to fit either and really are nice, but $.
Order of install of original FORD parts as others posted, steel washer against the Hyatt bearing, felt washer inside the cap.
The wheel hub also has a larger felt washer too.
Plus many place an extra inside axle seal, by removing the bearing and bearing sleeve, and sliding a special neoprene seal over the axle to seat at the ridge behind the sleeve.
Modern extra safely grease seal to be placed behind the removed Hyatt bearing sleeve.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Aug 27, 2025 6:11 pm
IIRC, installation of the inner neoprene seal requires shortening the inside end of the axle sleeve by the thickness of the seal (?)
Post by RajoRacer » Wed Aug 27, 2025 7:32 pm
The seals have been "modified" with a reduced face area for the sleeve clearance - not shown on the seal Dan was using !
Daisy Mae
First Name: Kurt
Last Name: Andersson
Post by Daisy Mae » Wed Aug 27, 2025 7:58 pm
I just rebuilt my '14 axle, and ran into that reality...
Between the early axle, and the neoprene seals, I had to shave a good 3/16th off the outer sleeves to flush everything up...
Before:
After:
Post by RajoRacer » Wed Aug 27, 2025 8:58 pm
Kurt - did you use the most recent seals with the relief ?
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Wed Aug 27, 2025 11:01 pm
Used the metal backed neoprene seals from Lang's
Post by Allan » Thu Aug 28, 2025 6:28 am
Removing something from the inner end of the sleeve is standard practise when fitting those inner seals. You need to take off the same amount as the thickness of the oil seal backing.
Last Name: Hatch
Post by Dan Hatch » Thu Aug 28, 2025 8:33 am
All you early car people need to read what Dan T wrote.
The early cars cups were a smaller size.
One year at Hershey I had some NOS ones on my infamous
Dollar table. Pointed them to people that I knew had early cars, they thought I was trying to BS them out of a dollar.
Like they say lead a horse to water but can’t make him take a bath.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Thu Aug 28, 2025 10:38 am
Thankfully my original outer seal cups were in good condition, I just oiled up new felts and reused the cups...
But Dan, ya don't happen to still have those NOS cups nobody wanted, do ya? I'll take them!!!
Post by RajoRacer » Thu Aug 28, 2025 11:19 am
Can't recall whose inner seals I recently ordered from, but they have a relief in the edge for the sleeve to set in - no cutting required !
Snyder's current seals show the relief ! If I remember correctly, Chaffin's began modifying those seals years ago.
Last Name: Hjortnaes
Post by DHort » Thu Aug 28, 2025 11:49 am
There should be an outer felt seal. Dan Treace's picture of a hub shows where it is placed. Too many people leave this out.
Daisy Mae
First Name: Kurt
Post by Daisy Mae » Thu Aug 28, 2025 2:49 pm
Steve, yes, the ones from Lang's have the relief as well.
Right/wrong/indifferent, I did dress up the outer relief (inner facing) edge with a thin layer of RTV to help seal the outer edge against the tube/face. But, thin/skim, certainly nothing that could have caused that much clearance issue.
949cathy
First Name: william
Last Name: bohlen
* REQUIRED* Type and Year of Model Ts owned: 1912
Post by 949cathy » Thu Aug 28, 2025 4:24 pm
Antique T Motor Sports offers a neoprene rear axle grease seal kits 1910-1927 and Ruckstell. These kits have been offer for 20 years. These seal kits have been developed to replace the traditional felt and rubber con. Ebay listing https://www.ebay.com/itm/388895448905
Post by speedytinc » Thu Aug 28, 2025 4:28 pm
I believe ATMS offers both early(small) & later(larger) outer seal caps.
Post by Allan » Thu Aug 28, 2025 7:27 pm
John, our ATMS only dispense money, no T parts! :D :D
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Aug 28, 2025 8:16 pm
I recently installed a set of the ATMS seals in a rear of a car I'm building. I like them very much, but I think Bill is looking to sell ATMS?
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Sat Aug 30, 2025 4:01 pm
Steve, The seals I used from Snyders was the same as you have pictured. I did not have to trim the bearing sleeve at all, it fit good.
