Oil on plugs
Will
Topic author - Posts: 191
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Oil on plugs
Had a small show to go to today, I noticed some oil on my sparkplugs, Is this normal? The car does not smoke at all.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Re: Oil on plugs
Oil on the outside of the plugs or inside around the electrode?
Will
- First Name: Will
Re: Oil on plugs
John, On the outside of the plugs
Re: Oil on plugs
Leaking around the threads or from the crimp of the base to porcelain? Its a mix of fuel & oil before combustion.
Threads can be sealed with a bit of anti seize. I prefer the conductive stuff. Mine is aluminum based.
There is a copper version also.
