Battery for a 14 Roadster
Topic author - Posts: 190
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
All you 14/13 roadster owners out there, where did you put your starting battery? On my 1915 touring I put a 12 vote dry sell on the main sill next to the gas tank but on the roadster there in no room to get a battery into that area.
Thank you Craig
Thank you Craig
- Last Name: Jablonski
Re: Battery for a 14 Roadster
6. Volt, group 1, Optima red battery.
Need some clarification. As a "starting battery" do mean just to start your T and then switch to magneto. A small one used for a winch or trolling motor, these are deep cycle batteries so then can be recharged many times & have good Ah & reserve capacity. Motorcycle/Lawn mower battery will work too. These can fit almost anywhereCraig E. Luton wrote: ↑Mon Sep 01, 2025 10:10 pmAll you 14/13 roadster owners out there, where did you put your starting battery? On my 1915 touring I put a 12 vote dry sell on the main sill next to the gas tank but on the roadster there in no room to get a battery into that area.
Thank you Craig
For an ignition battery, a 12 volt non-spill mower/ATV/garden tractor type battery does a fine job. They can be set up to charge off the magneto. For a cranking battery, the red top Optima battery is hard to beat. They don't leak or spill, they are lightweight, and they usually last a long time. Mine lays on its side under the seat, and it is about 12 years old, and it still starts the car. My charging system is a stock T generator and cutout. I would recommend using one of the available voltage regulators rather than a simple cutout. The stock system lacks adequate regulation and is hard on any battery compared with a proper regulator.
My 1913 runabout has a small coil size 12 volt battery in the tool compartment in back of the gas tank.
search.php?keywords=Battery+under+front ... d%5B0%5D=2 ..... Scroll down for more responses.
- First Name: Keith
- Last Name: Townsend
I have a 12v motorcycle battery tucked into the V shaped tool compartment next to the gas tank on my 1915.
Keith
Keith
- First Name: Craig
- Last Name: Luton
Keith; That is exactly what I was looking for. I don't know why I didn't think of using the tool box for the battery. That way I have an unobstructed route for the battery wire to the coil box and ground. Thank you Craig
