Rear spring questions
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Wed Aug 20, 2025 8:24 am
I want to put new bushings on the rear shackles and hit the leafs with graphite paint. The way I understand it is I have to take the wheels off then the diff off then the springs out. Is there a way I can take the springs out without removing the wheels? And regardless of how I get it out is there anything else I should be inspecting or replacing while I'm there?
Edit: I have done the job but the spring tie bolt isnt in the square hole, I tried a few times but combining weight, 2 other people I had helping, and shimmying it alot to get it to move up into the cross member I missed it by about the width of the bolt and I didn't want to keep at it, I am hoping the rattling of use will shake it into place. That in mind if anyone has any good ideas to center the spring with out taking that cancer back apart I would appreciate it. Thanks
John.Zibell
Last Name: Zibell
Re: Rear spring questions
Post by John.Zibell » Wed Aug 20, 2025 8:29 am
You don't need to remove the rear wheels, but you would need to raise the body much higher to relieve all tension on the spring. I would recommend removing the rear wheels. Be sure to have a spring spreader handy to do this job. It makes the task much easier. The bushings are in the spring and perches so having the wheels off will make access to the perches easier.
1926 Tudor
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Wed Aug 20, 2025 9:35 am
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Wed Aug 20, 2025 10:37 am
Has the rear axle ever been taken apart and inspected and rebuilt? Because this would be a good time if you are taking the shackles off.
Post by speedytinc » Wed Aug 20, 2025 11:25 am
I have found the easiest way is to pull the wheels & undo the perches from the backing plates. Takes all the tension off.
Seems easier to guide the perches back into the backing plates for reassembly. Work the perches back in with a 2x4 under the spring ends & jack.
Jack with a cradle or a jack on each side. Never under the center pumpkin.
Post by TRDxB2 » Wed Aug 20, 2025 11:35 am
This method works like a charm for removing bushings (even getting them in). The socket just needs to fit the ID of the spring & the OD of the bushing.
Rear spring restore
https://modeltfordfix.com/repairing-the ... ar-spring/
https://mtfca.com/phpBB3/viewtopic.php?t=30689
Post by Steve Jelf » Wed Aug 20, 2025 11:43 am
Here's one version of rear axle removal. Part of it may apply to what you're doing:
https://www.youtube.com/watch?v=8mZzAt9Q_4
You don't need a spring spreader to remove the shackles. Just loosen the perches enough to relieve the tension.
Last Name: Humble
Post by Humblej » Wed Aug 20, 2025 1:05 pm
Removing and installing rear axle spring shackles is covered in the Ford Service Manual.
Here is how I jack it up to relieve the spring tension.
Post by Original Smith » Sat Aug 23, 2025 12:23 pm
A bushing driver works nice. You may need to ream the bushing to fit the shackle. I would suggest brass, not a steel bushing.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Wed Sep 03, 2025 7:02 pm
My rear spring bushings on one side it looks like the spring hole for the bushing is too big as the bushing went in and out with hand force, as in I can pull it out, this would defiantly spin with use, how might I stop it from spinning?
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Wed Sep 03, 2025 7:10 pm
additionally I used the steel bushings, I hear Brass or Bronze ones were original or better, Ill keep that in mind for the future.I like buying from langs but the only bronze bushings i see are some for some part of a ruckstell, Ill have to see where I can get them from in bronze, maybe the other retailers.
Post by speedytinc » Wed Sep 03, 2025 7:16 pm
Make your own from an over sized bronze bushing.
Post by Allan » Wed Sep 03, 2025 9:25 pm
Bearing shops here carry bronze bushes to suit. i can buy one with greater wall thickness, so it can be turned down for a custom fit as John suggests. Do you intend to re-fit worn shackles? New replacements may need reaming the bushes to fit.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Wed Sep 10, 2025 10:27 am
I've tried 3 times to get the tie bolt head to fit in the square hole but I can't, I already put everything together, is there any way I can get the spring to just seat it self ? Like should I just go over some bumps and hope it slides in then I tighten it more on the u bolts?
Post by TRDxB2 » Wed Sep 10, 2025 11:33 am
Wondering if you squared up the radius rods. My firs attempt at this link said it wasn't available but eventually showed after some ads. So an ad may not have been available not the link https://www.youtube.com/watch?v=AfxWPsF4KhQ
Think you'll need to unshackle & put the spring in first
Last Name: Hjortnaes
Post by DHort » Wed Sep 10, 2025 3:00 pm
I do just like Jeff Humble does with a 4x4. Need to raise the rear almost 2 feet. Since you are not removing the rear axle, just leave the wheels on. Put a 2x4 under each shackle so all stays solid. Knock out the shackles. That bushing driver from Langs works great.........The old bushings should come out nicely, and the new ones might be a bit tight. You never know until you put the bushing in and push in the shackle. Might want to install the shackle in the spring so you know it fits OK, then pull it out and try it in the perches. You do not need to remove the spring unless everything is just too tght.
LittleTimmy52
First Name: Lucas
Last Name: Milatti
Post by LittleTimmy52 » Thu Sep 25, 2025 10:36 am
Status update, the bolt slid half way in, my driving got it that far but it hasn't moved past the half way point. I am wondering if I should loosen the u bolts a bit more and it might slide in because those u bolts are tight, if I loosen then it might slide the rest of the way into the cross member. How bad if an idea is that?
