Reproduction Headlight Rims
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Sep 09, 2025 8:20 pm
Is there still a problem with the fitting of the reproduction headlight rims? For some time I have heard or read that there were problems. I;m trying to decide whether to look for a decent original pair (26-27 plated) or go with some reproductions.
Re: Reproduction Headlight Rims
Post by Allan » Tue Sep 09, 2025 10:50 pm
Reproductions are a very distant second choice in my opinion. If you can find good 26-7 brass originals you are well ahead. Besides, the brass ones are easily dent knocked for polishing/replating.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Sep 09, 2025 11:31 pm
Allan, I totally agree that originals would be my preferred choice. I have some rims but they all would have to be replated, and with the cost of nickel plating these days, you might as well have a bunch of other small parts plated at the same time to make it worth it. I haven't seen an original pair of nickeled rims in the classifieds in a while, but if someone has a decent "driver quality" pair, I'm interested. I have a nickeled radiator shell with very good original nickel plating and I'm looking for a pair of rims in like condition. They don't have to be NOS or mint, but should not have any dents or places where the plating is worn through, and no broken lens clips on the inside.
Last Name: House
Post by George House » Wed Sep 10, 2025 7:14 am
I have a pair of nice original nickel plated rims I’d sell you Terry. Right up the road from you. I’ll send a photo in a few hours…. :D
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Sep 10, 2025 11:39 am
George, if you say they are nice, I won't worry about condition. Awaiting pictures and price with postage.
John Codman
Last Name: Codman
Post by John Codman » Wed Sep 10, 2025 11:55 am
I bought a set of repros and couldn't make one of them fit. They are the only parts that I have returned to that supplier. I had the originals replated with Nickle. Fortunately, except for the condition of the plating, the originals were perfect.
Post by RajoRacer » Wed Sep 10, 2025 12:10 pm
Some time ago, the only problem was the 4 rivets were too long - if you did manage to get them on, good luck removing them !!! Last set I received were O.K.
Last Name: House
Post by George House » Wed Sep 10, 2025 2:17 pm
Terry,… Found 3. Brass/nickel plated originals. No age cracks. All have 4 intact lens clamps. Your choice of 2- $20 each.
Last Name: Patrick
Post by jiminbartow » Wed Sep 10, 2025 8:20 pm
Good thing about originals is not only that they fit properly, but have the Ford script stamped into them.
Post by Allan » Sat Sep 13, 2025 5:03 am
I have noticed the Ford scrip on many US headlamp rims. It is nowhere near as prevalent on our Canadian sourced cars. Who knows why?
davet753
First Name: David
Last Name: Thomas
* REQUIRED* Type and Year of Model Ts owned: 1927 Runabout Sport
Post by davet753 » Sat Sep 13, 2025 6:38 am
The reproductions on mine do have the Ford script on them, and the rivets are (very slightly) larger than the originals. Because of this, it’s a real chore to get the rims off.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Sep 13, 2025 3:33 pm
David, When you say the rivets are slightly larger, do you mean they are slightly too long, which could be solved by grinding a slight amount off each one to shorten them, OR do you mean they are slightly larger in diameter?
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Sep 14, 2025 10:12 am
My reproduction rivets were too long. The rings took hours and swearing to remove. I shortened them with a grinder and I can get the rings off easily now.
davet753
First Name: David
Last Name: Thomas
Post by davet753 » Sun Sep 14, 2025 4:35 pm
Slightly longer; the diameter appears to be the same.
Like someone else suggested, I think they’d be fine by grinding off just a little bit from the end, or maybe just rounding off the edges some.
