Hassler spring install
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
Post by Wingnut » Sun Sep 14, 2025 9:31 am
Hello all, after the rebuild of a friend's rear axle we're having issues putting the springs in place. I wasn't involved in their removal so I didn't see how he got them out. This is on a 1920 touring with, what I'm told, is a California top. He has it on a lift which is a difficult install operation for me, I'm used to working on the floor. We've tried compressing them and wiring them, can almost get it but no cigar. Does anyone with experience in Hassler springs have a recipe method of install. We thank you for your support, Wingnut
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Hassler spring install
Post by Erik Johnson » Sun Sep 14, 2025 10:22 am
Hasslers came with a dedicated tool to compress the spring. However, you can compress the spring with it in the bracket with a homemade version using a piece of threaded rod, two nuts, a washer and a flat piece of steel with a hole drilled in it as I described here:
https://www.mtfca.com/discus/messages/1 ... 1281825166
And here:
https://www.mtfca.com/discus/messages/4 ... 1398691007
Post by TRDxB2 » Sun Sep 14, 2025 12:45 pm
Instructions +
Post by TRDxB2 » Sun Sep 14, 2025 12:48 pm
And there's more
1923hasslerinstructions.pdf
(389.43 KiB) Downloaded 32 times
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Sep 14, 2025 1:44 pm
If you make a tool yourself, it doesn't have to be as complicated/fancy as the Hassler factory issue tool.
As I posted above, a length of all-thread, two nuts, a washer and a flat piece of steel with a hole drilled in it will suffice to compress the spring in the bracket.
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Sun Sep 14, 2025 7:13 pm
Thanks , we'll give it ago with a home made version. really appreciate it . Wingnut
Post by TRDxB2 » Mon Sep 15, 2025 8:34 pm
As a safety precaution. have some kind of strap around a spring coil & the base its being attached to in case the the tool slips.
Post by RajoRacer » Mon Sep 15, 2025 10:20 pm
A good place for heavy nylon tie straps !
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Wed Sep 17, 2025 9:13 am
Thanks to all the great advice and tips, we made a tool as pictured, and BAM went together like a charm. Wingnut
