Trying to get my tires on split rims ( demountable ) to no avail , have used the rim tool , have used the turn buckle and the wooden plates with a Jack between them to help spread open to be able to latch them , but cannot get them to open up enough without them twisting . Any other ideas ?
Thanks .
21” split rims
Oldrusty26
Topic author - Posts: 74
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
- Board Member Since: 2012
- First Name: craig
- Last Name: leach
Re: 21” split rims
Hi Travis,
I have found that some rims have been twisted & need straightened to spread out round. I think this has to do with the rim tool pulls the rim
from one side pulling the rim in a conical direction. I find this more common on Chevrolet rims ( the rims may have been all made by the same
Maker.) I have found a need to use two rim spreaders one on each side to get them together straight enough to latch but they have to be straight
to start with.
to start with.
Re: 21” split rims
I think Craig hit it. Rims must be round & sit flat before mounting a new tire.
I have not had any problems using one rim spreader.
Look for past posts on where to mount & how to use.
New tires can be tight & need some screwdriver work to get the rim ends to meet.
Takes practice & patience. Dont force the rim spreader & bend a rim.
John.Zibell
- Last Name: Zibell
Re: 21” split rims
Since I have motorcycles, I also have a Coats 220 tire machine. I use the tire machine to collapse the rim and to remove the old tire and install the new tire. Then a rim spreader to expand the rim. The tire machine keeps the rim in one plane so it doesn't get twisted. If you can find someone with a manual machine, it makes tire changes much easier.
1926 Tudor
Oldrusty26
Re: 21” split rims
Thanks for that idea ,
