Two carbs on a single port fronty head?
Tallpaul
Topic author - Posts: 10
- First Name: Paul
- Last Name: Allen
- * REQUIRED* Type and Year of Model Ts owned: 1923
I have a single carb Frontenac head, and I’m wondering if I make a new intake manifold to accommodate a second Winfield carburetor, would I pick up more power?
Re: Two carbs on a single port fronty head?
You would cut the down the airflow in each carburetor by half, compared to running just one carburetor. I think it only makes sense if your one carb was undersized to begin with. That said, I am no carburation expert...
AndyClary
- First Name: Andrew
- Last Name: Clary
What size Winfield do you have now Paul? A B or BB should be providing plenty of flow for you.
Andy
Andy
Kevin Pharis
- Last Name: Pharis
From the ‘28 Winfield catalog;
And my flow estimates for the S/SR series carbs. Dual carbs is said to reduce efficiency by 20%
