Two carbs on a single port fronty head?
Tallpaul
First Name: Paul
Last Name: Allen
* REQUIRED* Type and Year of Model Ts owned: 1923
Post by Tallpaul » Mon Sep 22, 2025 7:26 pm
I have a single carb Frontenac head, and I’m wondering if I make a new intake manifold to accommodate a second Winfield carburetor, would I pick up more power?
Re: Two carbs on a single port fronty head?
Post by Jerry VanOoteghem » Mon Sep 22, 2025 7:30 pm
You would cut the down the airflow in each carburetor by half, compared to running just one carburetor. I think it only makes sense if your one carb was undersized to begin with. That said, I am no carburation expert...
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Mon Sep 22, 2025 9:49 pm
What size Winfield do you have now Paul? A B or BB should be providing plenty of flow for you.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Sep 23, 2025 12:02 am
From the ‘28 Winfield catalog;
And my flow estimates for the S/SR series carbs. Dual carbs is said to reduce efficiency by 20%
