How Far Should Timer Rotate?
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by mortier » Sat Sep 27, 2025 3:12 pm
My New Day Time doesn't seem to rotate far enough when using the spark lever. It only goes maybe 10-degrees (say from 12:00 to 1:00). Should it rotate the entire distance the spark lever does?
[url]https://youtube.com/shorts/ax16mite4Kg? ... =share/url]
Re: How Far Should Timer Rotate?
Post by speedytinc » Sat Sep 27, 2025 3:40 pm
No.
Spark lever@ the column connection is around .75" . Timer leverage is around 2". thats a 3x movement loss by design.
Make sure there is no movement loss in the lever connection to the rod. (tightly pinned).
Secondly original new day timers have an extra large linkage hole. A hobby tubing bushing will tighten that up.
Otherwise its normal.
Check your timing. Going from a roller timer to a new day changes the timing position. Timer rod needs new bends.
Post by Mark Gregush » Sat Sep 27, 2025 3:43 pm
You have it routed in the correct location but might be hitting the water pipe. Maybe reshape it and reset the timing as needed.
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Sat Sep 27, 2025 4:21 pm
I think bending the control rod would get me a little more advance. However, there is only about 5/16" before the timer/rod connector rubs the fan belt.
Post by speedytinc » Sat Sep 27, 2025 4:29 pm
Dont worry about advance. You will have plenty if you have the correct retard starting position.
At least, thats been my experience. I run a new day & have enough travel to overadvance with the spark lever all the way down.
Initial timing setting was way off & needed obvious correcting..
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sat Sep 27, 2025 5:00 pm
Your timer rod is hitting the pitman arm and has worn the paint off. Curve the end of the rod to clear the pitman arm. You may get more travel in your timer.
I had a similar situation and found that the lever that the rod connects to was not drilled correctly. I reversed the lever and gained a lot more movement. That should not have worked but it did.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Sep 27, 2025 5:54 pm
It looks like the linkage rod is scraping on the splash shield too.
Vern (Vieux Carre)
Ron Patterson
First Name: Ronald
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
Post by Ron Patterson » Sat Sep 27, 2025 6:33 pm
I cannot see why, but your timer is no rotating enough.
Perhaps the attached article will explain how it should work.
Ron Patterson
Model T Ignition System-Final Article.pdf
(388.82 KiB) Downloaded 97 times
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Sat Sep 27, 2025 6:36 pm
Pay close attention to figure 7 & 8 for correct range of motion.
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Sun Sep 28, 2025 5:02 pm
Yes, it wasn't rotating enough. I drove today, had a boil-over and lost half the coolant. Luckily, a farmer came out with a bucket of water and a funnel. One of our mechanically-minded drivers bent my spark rod up with a pair of pliers allowing much more movement. The power increased quite a bit.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Tue Sep 30, 2025 8:08 am
Mike Kosser wrote a simple procedure to verify the timer moves far enough between full retard and full advance.
Basically the timer needs to move at least 0.91" to get full range and best performance on any timer you use.
I stole them and have posted them here.
