Spencer fat man wheel ?
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT 25 runabout many misc projects
Board Member Since: 2012
Post by Oldrusty26 » Sat Sep 27, 2025 8:05 pm
Does anyone have any information about this wheel I picked up , is it for a T ? Where would I source a key for it ?
Last Name: Kuehn
Re: Spencer fat man wheel ?
Post by John kuehn » Sat Sep 27, 2025 8:52 pm
I have a Spencer steering wheel that was on my Grandfathers 24 Coupe. I’ll look in my shop tomorrow to see if it’s identical to yours. When I was restoring the car several years ago I took it off and used an original T steering wheel. I was going to use it but didn’t because I couldn’t find anyone who could repaint or reproduce the name tag. .I still may clean the Spencer wheel up and use it because my Grandfather did. I’m kind of sentimental about it I guess.
I don’t have a key for it either. I think mine is a lock wheel and not a fat man steering wheel.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat Sep 27, 2025 10:44 pm
A good, older, experienced locksmith can "impression" a key. I've had it done before. The problem is, there aren't many of those "good, older, experienced" locksmiths with us any more !
Post by Wayne Sheldon » Sun Sep 28, 2025 6:27 am
Spencer made fatman steering wheels for almost any car, in a variety of styles and sizes. Some folded up and above for if the car's control levers were below the steering wheel. Others, dropped down surrounding the steering column for cars with control levers above the steering wheel.
Yours is a special version made specifically for the model T Ford, positioning the rim of the steering wheel in line with the gear case for better steering control and close to the spark and throttle levers so that they can be reached easily by fingers without removing your hands from the wheel. These are fairly rare, although I think I have seen as many crawling out of the woodwork in the recent year or two as I have seen in the fifty years before!
I do have one of these, except mine is in much worse condition. One of the spider ends is broken where the wooden rim should be attached, The wooden rim is missing, as is also the entire cast iron base centerpiece. I have considered restoring it, and am certain I could. But I don't have a car I would want to use it on, and I have two nice fatman wheels if a car came along for me to need one.
Those name badges are often in poor condition. I don't know if those have been reproduced or not, or how many variations in printing and size they may have used?
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sun Sep 28, 2025 9:25 am
Thank you for the information
Last Name: Kuehn
Post by John kuehn » Sun Sep 28, 2025 6:24 pm
Here’s the Spencer lock wheel that I have. It was on the 24 Coupe my Grandfather bought in the early 40’s.
I’m wondering what kind of wood it’s made of. It’s complete but no key. I’m still thinking it’s just a locking wheel and not a fat man wheel. There is no mechanism thats moves or folds that I can see. I started to take the rim apart and glue the pieces back together years ago since the wood seemed solid. Anybody know how the pieces were secured together originally? Looks like the steering wheel is identical to the one Travis posted.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Sun Sep 28, 2025 9:23 pm
I was looking at mine tonight , and agree that it doesn’t seem to be any way to swivel it , I also agree they’re pretty much the same wheel
Last Name: Hatch
Post by Dan Hatch » Sun Sep 28, 2025 10:06 pm
Be careful with those “Locking Wheels “. Cause most don’t lock they unlock. They make the steering wheel free wheel. As no control. Some can unlock at highway speed. Happened to someone in our club many years ago. He ended inside down in a ditch. Dan
Post by DanTreace » Mon Sep 29, 2025 11:13 am
Found this info for the Lock and Tilting version on Google Books:
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Sep 29, 2025 5:32 pm
That is fantastic information, mine is just a locking wheel then ! Thanks again !
