Curious about FUEL TANK shape?
Topic author - Posts: 8
- First Name: Matthew
- * REQUIRED* Type and Year of Model Ts owned: 1918 Model TT Truck
I'm currently working on a speedster build and am curious if anyone here knows what these types of fuel tanks are called? I do not take credit for these photos.
Thanks in advance!
Thanks in advance!
Re: Curious about FUEL TANK shape?
I'd call it a "suitcase tank".
It definitely has that look! I appreciate your response. I seem to recall seeing a picture somewhere online of one of these tanks with the "Ford" logo stamped into it. Unsure what model Ford these types of tanks would be used in.
I tried searching for a "suitcase fuel tank" and couldn't come up with any fruitful results.
The search continues...
To repeat: "I'd call it.....".
In both pics, the bodies and tanks look identical, which suggests they were manufactured. If so, finding out who made them would probably be revealing. If both pics are the same car, or from the same custom builder, the tank may be a one-off. Both frames appear to be Model A Ford.
- First Name: Erik
- Last Name: Johnson
- Suitcase tank
- Dog house tank
- Lunch box tank
- Triangle tank
- Pyramid tank
- European racing tank
- British racing tank
No. 3 Racer tank, pre Caractacus Potts:
https://www.youtube.com/watch?v=UL4Gf2ydq2U
- Dog house tank
- Lunch box tank
- Triangle tank
- Pyramid tank
- Last Name: Jorgensen
I googled "Ford speedster gas tank" and found an image of a very similar gas tank that was made in Argentina. Perhaps you could find a fabricator of custom / replacement gas tanks that could fabricate a tank to your specifications. The hot rod community might help you locate such a fabricator.
This tank does appear to be a very efficient design for your application.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
WayneJ wrote: ↑Sun Sep 28, 2025 11:20 amI googled "Ford speedster gas tank" and found an image of a very similar gas tank that was made in Argentina. Perhaps you could find a fabricator of custom / replacement gas tanks that could fabricate a tank to your specifications. The hot rod community might help you locate such a fabricator.
I tried googling just that and even including 'Argentina' and couldn't come up with anything like you describe. Would you want to post an image of what you're coming up with?
No. 3 Racer ie. "Chitty" has been on of the inspirations for my T speedster! I'm just having a hell of a time pinning down what these dang fuel tanks are called.Erik Johnson wrote: ↑Sun Sep 28, 2025 11:09 am- Suitcase tank
- Dog house tank
- Lunch box tank
- Triangle tank
- Pyramid tank
Most speedster tanks I'm finding are oval or cylindrical.
Google: "Ford model a speedster gas tank argentina". Then look for a facebook post.
1918 Runabout
1918 Runabout
Got it, thank you. I don't have Facebook so I tend to ignore most links taking me to it.
Its seeming like I might be better off going with a typical T tank or if I'm feeling super motivated I could fabricate a tank to be exactly what I'm looking for.
Thank you!
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
I doubt that they are the same car, as one appears to be right hand drive and the other left hand drive.TXGOAT2 wrote: ↑Sun Sep 28, 2025 8:38 amTo repeat: "I'd call it.....".
Keep crankin',
Eric
- First Name: Jeffrey
- Last Name: Hausey
Not really blastfamy if you modify it. Repops are out there.
- First Name: Henry
- Last Name: Lee
I use to build any style the customer wanted but due to no one wanting to pay a craftsman a decent price, many sheetmetal guys have quit or died off. It must use baffles (2), a seam 2/3 from the bottom, and a flexible mounting strap system to accommodate the frame movement of the T. Good luck in finding someone.
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Henry,
Your knowledge, and willingness to share is what makes this forum great.
I do not possess your skill level, but I’m not afraid of trying to fabricate parts that I can, when needed.
I will file away the info on tank building for future use
Scott
Scott
I appreciate your insight. It all comes down to how badly I want this style of fuel tank and how much money or my own time I'm willing to throw at it to achieve it. All part of what makes these projects special!Henry K. Lee wrote: ↑Mon Sep 29, 2025 6:10 amI use to build any style the customer wanted but due to no one wanting to pay a craftsman a decent price, many sheetmetal guys have quit or died off. It must use baffles (2), a seam 2/3 from the bottom, and a flexible mounting strap system to accommodate the frame movement of the T. Good luck in finding someone.
- First Name: craig
- Last Name: leach
Hi Matthew,
Have you considered building a metal box in the shape you desire & putting a tank inside of it like a 10 gal. aluminum sand rail tank or a
rectangular hot rod tank? That would be less chance of leaking & safer to assemble. And may be less cost?
- Last Name: Corman
Fordson tank looks stunning and it's all Ford then
- Last Name: Corman
- Last Name: Pharis
Despite his less than optimistic view of the world, Hank provides good design advice. If you hire help, tell em it’s a water tank. Certain words like car, road, fuel, and gas will cause most shops to refuse the project due to liability concerns. I would only add that the end caps should not be held on with solder alone (or solder at all). Crimp and rivet your seams prior to soldering to prevent solder fatigue and leaks. I prefer to welded tanks
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Those are the bodies built in Argentina. Everything was hand crafted. There is a nice article about them in Secrets of Speed Magazine.
I think it was Rio Tercero.
Craig,Craig Leach wrote: ↑Mon Sep 29, 2025 1:07 pmHi Matthew,
Thanks for this idea! Sometimes the simple solutions can be the best. My metal working skills are OKAY, and certainly not suitable for building a liquid-tight container such as this. I may have to use this idea.
- First Name: Henry
- Last Name: Lee
Kevin, You nailed it! Say it is for water! The joints are "Pittsburg" style which hold firm and are either soldered or epoxied. Modern solder is trash and finding good acid is even worst. Still debated whether to offer to build this as the metal forming skills are disappearing quickly.
Where the hell is Lewistown?
