Engine oil
Jim Byrne
First Name: Jim
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1917 model t
Engine oil
Post by Jim Byrne » Wed Oct 01, 2025 11:08 am
I am a new 1917 T owner and want to know what the best choices are for engine oil and coolent
Re: Engine oil
Post by speedytinc » Wed Oct 01, 2025 11:22 am
My preferences.
Valvoline racing 30 wt. Any good detergent 30 wt will do.
Water soluble oil for the radiator in distilled water. Sold @ auto parts stores as "anti rust & water pump lube."
Buckle up. Many opinions coming.
Re: Engine oil
Post by TXGOAT2 » Wed Oct 01, 2025 12:10 pm
Ford recommended what amounts to 20W, but what did they know about Model Ts?
Last Name: Humble
Board Member Since: 2006
Re: Engine oil
Post by Humblej » Wed Oct 01, 2025 12:47 pm
10w 30 oil and 50/50 conventional coolant.
big2bird
First Name: Jeffrey
Last Name: Hausey
Re: Engine oil
Post by big2bird » Wed Oct 01, 2025 1:07 pm
My preferences.
This^^^^^^^
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Re: Engine oil
Post by Charlie B in N.J. » Wed Oct 01, 2025 1:28 pm
As stated: 10W 30 oil and 50/50 coolant. Don’t bother with non detergent 30W. Gets too heavy in winter. Experience talking here.
Re: Engine oil
Post by John kuehn » Wed Oct 01, 2025 3:07 pm
Save your money and go to Wal Mart, Auto Zone, Oriellys and buy their store brand 10w30, or 10w20 HD oil. It’s much better than oil Ford ever put in Model T’s.
love2T's
First Name: T
Last Name: Gates
Re: Engine oil
Post by love2T's » Thu Oct 02, 2025 9:32 am
John, Menards (we pronounce it "MAYnerds ha ha) actually has Rotella 10w30 usually for LESS than the "off brands" at auto stores. You can't beat the quality of Rotella. And if you're concerned about zinc and phosphorous it's still got the highest levels "allowed".
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Engine oil
Post by Jack Putnam, in Ohio » Thu Oct 02, 2025 9:56 am
But whatever detergent oil that is on sale, it will be better than what was available a 100 years ago.
babychadwick
First Name: Chad
Last Name: Azevedo
Re: Engine oil
Post by babychadwick » Fri Oct 03, 2025 9:22 am
10w40 here, but then its a hotter engine with an oil pump where I'm not dependent on the Ford splash system. In the past coolant has just been water as it leaked out so fast there was no point in antifreeze. With the new radiator (something needed for the past 40 years) and rebuilt water pump I can now run 50/50
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Re: Engine oil
Post by CatGuy » Fri Oct 03, 2025 10:32 am
How much of an effect does the different weight of oil have on the transmission function? Any?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Engine oil
Post by Rich P. Bingham » Fri Oct 03, 2025 11:17 am
Viscosity affects clutch function. Heavy (cold) oil will cause the car to creep in neutral.
Get a horse !
Re: Engine oil
Post by TXGOAT2 » Fri Oct 03, 2025 12:31 pm
Model Ts are designed to use what Ford called "light cylinder oil", which is about 20W. Ford recommended a quality "Light" oil for general use, and recommended a light oil mixed with 10% kerosene in cold weather. The lubrication system will not function as it is supposed to with thick oil, and neither will the clutch and bands. Thick oil might also contribute to problems with triple gear bushings, and it will make starting more difficult. Thick oil will interfere with roller timer function, especially in colder weather.
For a stock or near-stock T engine, a good 10W30 is an excellent choice. In cold weather areas, 5W30 or 5W20 is a good choice. There is no good reason to put thick oil in a Model T, and a number of good reasons not to.
Re: Engine oil
Post by Original Smith » Fri Oct 03, 2025 1:35 pm
I like Valvoline oils. I use 15-40, 10-40, 10-30. They all work fine here in Southern California.
Jim Byrne
First Name: Jim
Last Name: Byrne
Re: Engine oil & coolant
Post by Jim Byrne » Sat Oct 04, 2025 11:45 am
Thanks, guys---I appreciate the responses---Looks like I will try 10-30 oil & 50/50 coolant
The last owner told me he used some type of hydraulic oil in it (hope it hasn't done any damage).
Re: Engine oil
Post by TXGOAT2 » Sat Oct 04, 2025 12:02 pm
10W30 is a good choice for most localities. I don't know why anyone would put hydraulic oil of any type in an automobile engine, including a Model T. That said, I doubt if it did any damage. Most hydraulic oils are light bodied, temperature stable oil with anti-foam additives and good lubricity and film strength. But motor oil designed for gasoline engines is best for a Model T with a stock or near-stock engine. Any good 10W30 motor oil will meet, and far exceed, all Ford's motor oil specifications for the Model T. Conventional oil, synthetic blend, or full synthetic oils all work well. If you run your car in cold weather, a 5W20 or 5W30 is a good choice. Thick oil is not needed and NOT RECOMMENDED for use in Model Ts for a number of very good reasons. Multigrade detergent oils offer many advantages, and there is no good reason not to use it.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Re: Engine oil
Post by Charlie B in N.J. » Sat Oct 04, 2025 12:05 pm
Jim: you made the right choices. You’re going to find over time here at the Forum that there are people out there that just HAVE to experiment on their T’s. They try the damndest things and swear on a stack of bibles and Grandpa’s grave that it works. Use what you’d use in your modern and you can’t go wrong.
Re: Engine oil
Post by Jerry VanOoteghem » Sun Oct 05, 2025 4:21 pm
Agreed. More important than the particular grade of oil, just make sure you always have enough in the engine. Check it with every fuel-up, at least until you get accustomed to its normal oil use.
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Re: Engine oil
Post by fbergski » Fri Oct 10, 2025 12:57 am
Wally ST 5w-30 or 10w-30 oil works fine for me.
bobt
Last Name: Thompson
Re: Engine oil
Post by bobt » Fri Oct 10, 2025 6:21 am
Oil Wet-n-slick. Coolant 50/50 Distilled H20 and Green stuff. bobt
First Name: Adrian
Last Name: Whiteman
Re: Engine oil
Post by A Whiteman » Fri Oct 10, 2025 1:22 pm
No matter what oil you choose, your T engine will use and mostly leak a lot of the oil so it is important to remember to regularly check the oil level (before each drive is a good habit to get into). Never let it get below the lower oil cock.
Have fun :-)
Re: Engine oil
Post by Steve Jelf » Fri Oct 10, 2025 2:40 pm
Re: Engine oil
Post by Norman Kling » Fri Oct 10, 2025 5:45 pm
The oil system is gravity fed and splash, so it is not under any pressure. The lighter weight oils will actually give better lubrication.
Last Name: Hjortnaes
Re: Engine oil
Post by DHort » Sat Oct 11, 2025 1:23 pm
And if you have to room, store a couple quarts of oil somewhere in the car and an empty bottle that u can use to add water to the radiator, even if it is just an old coke bottle.
Re: Engine oil
Post by TXGOAT2 » Sun Oct 12, 2025 10:51 am
I liked the old style steel quart oil cans... but the liquor bottle style plastic quarts are easier to store in a car. All gas stations used to have air and water for free.... and most had motor oil out front in a rack. But most no longer have water or air, and convenience store oil is often high priced.
