BAD ROD ADVICE
Art Ebeling
Topic author - Posts: 515
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
BAD ROD ADVICE
I looked at a 26 sedan today that a new owner had questions about a knocking noise. This car is a recent purchase of a "full restoration" that had a knocking engine after less than three miles of driving. The number two rod babbit is beat out and I am wondering about cleaning up the crankshaft rod journal. I checked the journal for size and it is standard. Does this rod journal look like it will clean up? I can't feel any scratches and I think what looks dull is babbit material that I will have to clean off. I will check the other rods and check the internal oil tube, maybe the mains. Any suggestions or other advice? Thanks, Art
TrentB
- First Name: Trent
- Last Name: Boggess
Re: BAD ROD ADVICE
I have seen something similar to this in an engine that had been run without oil.
Re: BAD ROD ADVICE
You can clean off the babbitt and polish the journal, then carefully check it for roundness, taper, and size. The replacement rod can be fitted for size, if the journal is an off-size, but the the journal must be round and straight. There are a number of reasons why the bearing could have failed.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
How would you clean and polish the journal? Thanks, ArtTXGOAT2 wrote: ↑Sat Oct 04, 2025 6:00 pmYou can clean off the babbitt and polish the journal, then carefully check it for roundness, taper, and size. The replacement rod can be fitted for size, if the journal is an off-size, but the the journal must be round and straight. There are a number of reasons why the bearing could have failed.
Re: BAD ROD ADVICE
"Crocus cloth" is often recommended for polishing crankshaft journals. Something like emery cloth with light oil would probably work OK. I'd use a pocket knife to gently scrape away the smeared babbitt. Scotchbrite might work to remove babbitt.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
Re: BAD ROD ADVICE
Sure looks like a run dry bearing to me, being a new rebuild maybe clearance set too tight ?
I'd certainly be pulling every cap to check/verify.
Re: BAD ROD ADVICE
Long strip of fine emery cloth. Work like doing a shoe shine. Will polish about 1/3 @ a time. Rotate crank to several positions for an even polish.Art Ebeling wrote: ↑Sat Oct 04, 2025 6:05 pmHow would you clean and polish the journal? Thanks, ArtTXGOAT2 wrote: ↑Sat Oct 04, 2025 6:00 pmYou can clean off the babbitt and polish the journal, then carefully check it for roundness, taper, and size. The replacement rod can be fitted for size, if the journal is an off-size, but the the journal must be round and straight. There are a number of reasons why the bearing could have failed.
More interesting is WHY did this happen? Normally oil loss takes out #1. Definitely check the inner oil funnel/tube.
You will need to check all the other rods for babbit condition & contact.
Restoration?? Who? Credentials? The corner gas station guy?
The answer to this would help decide whether or not to do a complete teardown. Was this a freak incident or the tip of the iceberg in a poor rebuild? Many more issues to follow? Never be able to trust the T waiting for the next mistake to make itself known.
Talk to the "restorer"
Tight piston? Tight wrist pin? Bent rod? I have yet to purchase a set of rods or remove a set from a motor that didnt have at least 1 bent enough to not need straightening in a set!! TRUST NO ONE.
Sorry to be such a bummer, but I have had to re-rebuild quite a few builds from incompetent T mechanics. Its all in the details.
michaelb2296
- First Name: Michael
- Last Name: Bunner
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Re: BAD ROD ADVICE
Pictures #4 & #5 confuse me. Dirt, delamination, dirty piston where the wrist pin is. Doesnt add up.
But, maybe poor lighting? Idk. Im not there.
Question, with everything torqued down tight, could you easily hand crank through all 4 pistons (up/down) or was it too tight?
If no movement from the start, then delamination will occur.
I.e. pop/drag and go and hope for best is probably not the best solution.
If you can fix just the one thing and the other journals/rods look great then i would make sure the new #2 rod/piston/rings/journal rotate freely, fully torqued , without binding (<- a big deal) and try again.
We all learn through mistakes but as others have questioned maybe the rebuild was done by a good intentions person with little experience? It happens. Even if they are an EXPERT problems/mistakes can happen! Don’t ask me how i know…
Tight , is no good.
Tight , is no good.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: BAD ROD ADVICE
It is a typical “burnt out bearing”. The babbitt instantly liquifies, slings out, and solidifies. It is usually from too tight clearance OR too little oil (or too much load on the engine). The inside oil line may be plugged or oil level too low. Maybe the babbitt quality is poor, but more than likely it was low oil, plugged oil line, or heavy loading (lugging the engine).
NoelChico
- First Name: Noel
- Last Name: Chicoine
Re: BAD ROD ADVICE
I had a No. 2 rod that looked like that several years ago. A week before the Hamilton tour I tightened up some slightly loose rods, put it together, and had a rod knock at about 30 seconds of running. Maybe I forgot to put my usual "motor honey" on the rod cap on re-assembly. Maybe I adjusted it too tight. But I DID forget to put half a quart of oil in the filler, filling the dips on start-up.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
Thanks for the answers. I don't know who restored this vehicle and I asked the owner if he thought he could get any help from the person he bought it from and he did not think he could. I will continue to disassemble and check everything. My main concern now is to try to determine the cause and clean up the crank. My personal opinion is that the restoration consisted of paint and gaskets.
Re: BAD ROD ADVICE
Do you know how much the engine has run since it was rebuilt, if it was rebuilt?
Another thought: Starting a new or rebuilt engine that has thick oil in the crank case in cold weather can result in oil starvation to bearings.
Adam
- First Name: Adam
Re: BAD ROD ADVICE
Use of thick assembly lubes and the presence of grease inside the engine can also seal up the areas that provide oil and cause a bearing to run dry and fail. Grease and some assembly lubes do not mix readily with oil in engines that do not have a pressurized oil system.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Re: BAD ROD ADVICE
This one is a tough call. Fluke or more issues?
Tough hand to play.
Tough hand to play.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
I dug into this deeper this morning removing the other three rod caps. The babbit looks good but none of the rods have shims and there are file marks on the caps. I might plastigage them but I am leaning towards four new rods. I think someone has just filed them to fit. This “rebuilt” engine also has two piece valves. What are your opinions? Thanks Art
big2bird
- Last Name: Hausey
Re: BAD ROD ADVICE
Nobody rebuilds an engine with 2 piece valves.
I would pull it with that tid bit.
Re: BAD ROD ADVICE
No shims and file marks indicate a worn engine with a shoddy "overhaul". In recent decades, any decent overhaul or valve service job would include replacing composite valves. Ford disowned the composite valves around 1926.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
I want to verify that these are two piece valves. They have the two holes on top. Art
big2bird
- Last Name: Hausey
Re: BAD ROD ADVICE
Yes........
Re: BAD ROD ADVICE
Verified....
Re: BAD ROD ADVICE
What I would call an Ice Cream restoration, looks pretty on the outside to go get Ice Cream or local 4th of July parade with the grandkids, but underneath nada was done to the car.
Re: BAD ROD ADVICE
I think this rebuilt T got a nice repaint and body cleanup looking at the pictures.
The engine was “freshened up” and not necessarily rebuilt sometime in the past and that’s about it.
Looks like it has the original valves and the rods filed for a better fit up. But if it’s got the older 2 piece valves I don’t think the engine was renewed or rebuilt.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
Would you use X’d rods or non X’d rods? Art
Re: BAD ROD ADVICE
As far as I know, Ford didn't use X'd rods. They did describe the correct way to finish new babbitt.
big2bird
- Last Name: Hausey
Re: BAD ROD ADVICE
I would use X rods with scoops.
J and M Machine
- Last Name: Gulbankian
Re: BAD ROD ADVICE
With the amount of dirty oil discoloration in the engine I doubt it came apart for a thorough rebuild.
The connecting rod wasn't tinned as babbitt needs tin to fuse to as babbitt doesn't stick to steel.
I would recommend you go through the engine methodically as i doubt anything has been done to it other than a spray can paint job to the block.
We always see this type of rebuild when they spend all the money on the body but "Don't Open the Hood"!
Re: BAD ROD ADVICE
This T was sold to the person that Art E. knows took the advice that it was restored by the seller. Since the body looks it was at least being close to ‘restored’ what about the differential and front end?
The engine will probably have to be pulled and checked out along with the transmission.
In the long run that’s the best option.
Maybe the seller/rebuilder sold the car thinking that the mechanical part was OK but it really makes you wonder. I don’t have a machine shop or rebuilt scores of T engines but only 4 but when I noticed the 2 piece valves that was a dead giveaway the seller didn’t know much about T engines.
Art Ebeling
- First Name: Art
Re: BAD ROD ADVICE
I have been using the word "rebuilt", the owner clarified that and told me he was not told it was rebuilt but restored and gone thru. All in all it looks like a nice car. Art
Re: BAD ROD ADVICE
......... with another $6,000 in mechanical work.Art Ebeling wrote: ↑Tue Oct 07, 2025 11:41 amI have been using the word "rebuilt", the owner clarified that and told me he was not told it was rebuilt but restored and gone thru. All in all it looks like a nice car. Art
This situation is all too common.
But, that's the way I like to buy a personal car.
Ill do the mechanics & be able to rely on the machine for a lifetime + of service.
Re: BAD ROD ADVICE
After a proper rebuild, the new owner will no doubt have more $ in the car than "market". However it will be a reliable car with a long mechanical life expectancy that could be expected, with reasonable care, to provide many, many miles of reliable service with minimal further expense.
Re: BAD ROD ADVICE
My advice, which I have shared with several would be buyers, assume a complete engine overhaul, absent of conclusive proof otherwise, pay accordingly. That prices the prettiest T's in the $6-8K range. Add the extra $6K for the rebuild. You are in for $12k. You still may not be able to recoup all your investment in $, but you will be ahead factoring in the fun & experience of ownership.
big2bird
- Last Name: Hausey
Re: BAD ROD ADVICE
Not rebuilt but restored?Art Ebeling wrote: ↑Tue Oct 07, 2025 11:41 amI have been using the word "rebuilt", the owner clarified that and told me he was not told it was rebuilt but restored and gone thru. All in all it looks like a nice car. Art
WTF does THAT mean?
"Your honor, I said restored not rebuilt." LOL
Re: BAD ROD ADVICE
All tire pressures were thoroughly checked, Your Honor!
