Could use your help - '27 coupe w/ Holley NH
Mike S
Last Name: Sibley
Board Member Since: 2025
Post by Mike S » Mon Oct 06, 2025 10:45 pm
The choke/mixture rod evidently was replaced with one that really does not fit this car as it is too long and sticks out of the dash about 4 inches.
I had the carburetor (bayonet type not t-top) rebuilt but I am having trouble with the choke/mixture operate the carburetor to operate properly. The location of the small holes where the choke rod attaches is on top of the input manifold, which makes it extremely hard to adjust the mixture. Also it does not have enough play to properly choke the carburetor.
I am thinking about extending the rod from the choke to a location that makes it easier to operate both functions. Would anyone have a photo of similar that operates properly? I would really appreciate it as I just have a wire between the choke on the carb to the proper location on the rod?
I've tried to find a shorter choke/mixture rod maybe more for this actual car but have not been successful.
Thanks,
Mike
Mike S
Last Name: Sibley
Re: Could use your help - '27 coupe w/ Holley NH
Post by Mike S » Mon Oct 06, 2025 10:51 pm
PS - I'm trying to add a collar to put it above the intake but at that location it tends to hit the firewall not letting the rod pull enough distance to engage the choke properly.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Oct 07, 2025 6:45 am
Here is how it is done for the NH according to the Ford Service Manual.
Mike S
Last Name: Sibley
Post by Mike S » Tue Oct 07, 2025 7:24 am
Thanks! I am not an experienced auto mechanic but I am trying to learn. My wife bought this car for me and I am doing my best to get it up to snuff. I appreciate all your help.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Tue Oct 07, 2025 7:26 am
Mike, I just had to deal with all this on our Coupe. I believe the two bolts mounting the carburetor to the intake manifold are 3/8". You may need to loosen them, rotate the carb. so that the screw closest to the engine goes up, and that the screw closest to you goes down. While holding the carb with some channel locks wrapped in a shop towel, hold it in this rotated position. Then with another hand use a 9/16" open wrench to hold the screw and with another hand/9/16" open wrench, tighten the nut. A little bit of rotation is magnified by the tall mixture adjustment needle.
I had gouges in the hot air collection pipe it was so close. I also, with a high speed mini grinder, removed 1/16" material from the hot air pipe where it contacts the exhaust manifold.
I also relocated the slider higher up on the choke rod by drilling holes to a new location.
The rod itself is sold longer than you need. The installer is supposed to cut it down to size. That is why it sticks out the dash. Ours no longer does stick out.
Vern (Vieux Carre)
Post by RajoRacer » Tue Oct 07, 2025 11:13 am
If the combination mixture/choke rod was replaced, most likely with a repro, one drives out the tension pin holding the adjustment knob, shorten the rod as needed, reattach the knob, redrill the hole & reinsert the tension pin.
Ford supplied a "special" hot air pipe with indentation for the swivel top carburetors so as to not have that interference issue.
Post by Original Smith » Tue Oct 07, 2025 11:16 am
Check the parts book. There are seven different lengths of adjusting rods used. I went through that with my late 25, and had an interesting time trying to locate the correct length. Keep on trying.
Post by DanTreace » Tue Oct 07, 2025 12:02 pm
For the repro needle valve, that replacement has longer arms or fingers than the originals (provides the tension on the round barrel to keep the needle valve in correct spot) can interfere with the hex portion and prevent full seating of the needle.
My fix is to cutaway a portion of those arms (neat job no, but results are right :( )...... just another thing with repro parts. Cut back the arms improves function, be sure to crimp the arms just a bit to get the proper tension to prevent drift.
modifed repro parts.jpeg (99.64 KiB) Viewed 1041 times
528269 (494x500).jpg (95.99 KiB) Viewed 1041 times
Mike S
Last Name: Sibley
Post by Mike S » Wed Oct 08, 2025 11:02 am
Thanks, I am learning so I appreciate the advice!
The adjustment rod on this car has a black Bakelite type knob on the top and I cannot seem to locate a set screw or anything to reattach it if I cut it. Also, when I set the fitting over the choke rod that pulls the choke, the rod wants to come out of the bayonet fitting. I am going out to work on the vehicle this morning so I will try to get it better using everyone's advice.
Post by RajoRacer » Wed Oct 08, 2025 11:54 am
Sounds as though the P.O. did some "handywork" of his own - the knob coming out of the dash is/was aluminum and the square shank is quite long - I'll measure one today & post a photo.
Mike S
Last Name: Sibley
Post by Mike S » Wed Oct 08, 2025 4:33 pm
Obviously, the previous owner put this in without using the correct part. Two issues, the knob at the top is not removable to allow me to cut the rod and replace the knob so I am ordering one from the parts suppliers that now love me! Photo is attached. The rod is 28 7/8 inch long.
I found a Model A repair manual in the car after we got it, so obviously this part might have been for a Model A.
The second issue is that the first hole in the rod is 4 3/8 inch from the tip which puts the gizmo that the choke connection attaches to which puts it in the center of the manifold. I need to either replace the whole thing with a new rod or drill new holes, cut to the right length and put a new knob on the top.
PS - the square portion of the rod is only 1 7/8-inch long.
Post by DanTreace » Wed Oct 08, 2025 9:29 pm
The vendors sell a replacement that is long and you cut to length, the knob is held with a split type pin. That is what you need.
Perhaps your rod is for the Vaporizer Carb adj. rod and knob assembly, for the Fordor it's 29 9/16"
The rod for your 27 Coupe is either 4129F, 27 13/16" or the 4129G , 26 1/4" long and the square section is longer too.
Vaporizer rod shown in this photo, choke arm higher.
NH rod with choke arm lower on the rod. Rod shown is the vendor version, sometimes needs a bit of tweaking to the square shaft to slide easily in the square tubing. Filing a little. The goal is a nice fit, but keep from rattling too, the square end long enough to slide up for full choke movement, but not too far that the end of the rod pulls out of the square tubing.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Thu Oct 09, 2025 7:00 am
If the square end is only 1-7/8" then someone cut the wrong end.
Vern (Vieux Carre)
Mike S
Last Name: Sibley
Post by Mike S » Thu Oct 09, 2025 9:28 am
I ordered a replacement rod and the connector rod for the choke. Better to start over than trying to fix someone else's issues.
Thanks for all your help everyone.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Oct 11, 2025 5:10 pm
Most of the time, I have had to remove the handle part by punching out the pin.
Then, sawing off the extra.
Then, drilling a very small hole and replacing the pin.
Drills the small break easy if you press too hard, you have to let the drill do the cutting!
