Ben's Model-T Pie Wagon [1911-1925]
Re: Ben's Model-T Pie Wagon [1911-1925]
If you carry loads, a Ruxtel would be a good accessory. Improving the brakes will have benefits, but you will still have very limited braking due to lack of any front brakes. The disc brake conversion would pair well with a Ruxtel axle.
Topic author - Posts: 105
- First Name: Ben
- Last Name: Piraro
- * REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Well I see this forum does use pages.... was wondering when it would roll to page 2.
as of right now, I am using straight 30w non-detergent oil (PureGuard).
I will look into this some more...TXGOAT2 wrote: ↑Tue Oct 14, 2025 3:36 pmI would not put STP or any similar product in a Model T engine. Model T engines and transmissions require "light cylinder oil", according to period Ford specs, which is about what today's 20W is . 10W30 detergent oil does a great job in a Model T under most conditions. If you drive in colder weather, 5W30 or 5W20 does a good job. Thicker oil causes a number of problems with Model T engines and transmissions, and it is not needed and specifically not recommended by Ford Motor Co. 10W30 exceed all Ford's specifications for motor oil for use in the Model T.
A ruckstell is on the list! Maybe towards the end of the list, I need to get all the major safety items crossed off.
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
https://www.youtube.com/watch?v=e5FPWnxG_9w
You'll get better results with a good 10W30 detergent oil. Regular 10W30 oil, synthetic blend, or full synthetic all work fine. In cold weather, 5W30 or 5W20 are best. Both the engine and the transmission need a light bodied oil that does not thicken up in colder weather. Multigrade oil will outperform any straight grade oil in a Model T under all driving conditions, and detergent oil offers the same benefits in a Model T as it does in a new car. No downside to it.
