Ring Gap!
Abakca
First Name: Alfredo
Last Name: Lira
* REQUIRED* Type and Year of Model Ts owned: 1920 touring
Ring Gap!
Post by Abakca » Fri Oct 17, 2025 3:06 am
Hello, my cylinders are bored at .060, aluminum pistons, top ring gapped at. 010, I have driven about 30 miles. Im terrified because I misinterpreted the paper that came with the rings. It said do not file top ring. Apparently they meant do not file off the top coating of the top ring. I did file ring 2 nd three to gaps of 15 nd 18. Do it need to pull it apart and gap the top rings wider or am I ok? Grant rings, first timer here. And yes im posting this at 12 am Hawaii time, im losing sleep over it lol
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Re: Ring Gap!
Post by Dodge » Fri Oct 17, 2025 4:28 am
That top ring should have a minimum of .015 but closer to .018. At .010 if you overheat it or run it hard you will have a problem.
Sorry, but you should pull the pistons out and redo the end gap.
bobt
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1915 touring 1926 roadster
Re: Ring Gap!
Post by bobt » Fri Oct 17, 2025 6:06 am
after 30 miles and rings seating, I'm saying go with it. According to Steve Lang , a lot of people gap at 10/11. bobt
First Name: john
Last Name: karvaly
Re: Ring Gap!
Post by speedytinc » Fri Oct 17, 2025 8:06 am
Top ring will expand the most due to being in the hottest position.
T motors don't cool as well as a modern engine. Pull them.
Re: Ring Gap!
Post by TXGOAT2 » Fri Oct 17, 2025 10:08 am
Ring gap specs are probably based on an allowance for the gaps to increase due to break-in seating. The problem with a ring gap that is too small is that if you have trouble, it will be BIG TROUBLE. The piston to cylinder fit is also critical, and the fit needs to be correct for aluminum pistons, if that's what you have. Original Ford specs are for cast iron pistons, and are wrong (too tight) for fitting aluminum pistons.
Adam
First Name: Adam
Last Name: Doleshal
Re: Ring Gap!
Post by Adam » Fri Oct 17, 2025 10:16 am
You are a bit below the balance point. Cast iron (the ring) expands .001” per inch with a 200F temp rise. The ring is 11.77” long if it was straightened out, therefore will grow just under .012” with a 200F rise. But, the block will warm up proportionately and so will the pistons (bore gets slightly larger and so does the piston).
Any gap smaller than .012 is getting pretty “tight”. A .012” gap if it is absolutely accurate is probably still okay. .010” might be a little dicey. Maybe will wear in and open up a little. Maybe not.
Re: Ring Gap!
Post by TXGOAT2 » Fri Oct 17, 2025 11:18 am
Do you have a water pump on the vehicle?
Re: Ring Gap!
Post by TXGOAT2 » Fri Oct 17, 2025 2:57 pm
Cold this be a job for...... MARVEL MYSTERY OIL?
Dodge
First Name: Dodge
Last Name: Riedy
Re: Ring Gap!
Post by Dodge » Fri Oct 17, 2025 3:11 pm
Also when the pistons are out check the piston to wall clearance. Should be .004 or more. If the bore is too small that could be one
of the reasons your ring gap is so small. You could have double trouble......
Re: Ring Gap!
Post by TXGOAT2 » Fri Oct 17, 2025 3:25 pm
Engine has aluminum pistons....
Abakca
First Name: Alfredo
Last Name: Lira
Re: Ring Gap!
Post by Abakca » Sat Oct 18, 2025 3:43 am
Thanks to everyone for the responses and advice. I couldn't sleep all night thinking about it so I just re gapped them. I will say the second time around was significantly faster. The first go around took me 12 hours. This time I was done in half the time! Better safe than sorry!
