Does this original speedster look like a commercial or homemade body?
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Thu Oct 23, 2025 1:10 am
A client sent me this picture of a speedster his grandfather built. The client would like to know if the body is factory or homemade? I think it looks close to the Champion model A body, but I invite your opinions.
Chris
Re: Does this original speedster look like a commercial or homemade body?
Post by TRDxB2 » Thu Oct 23, 2025 11:39 am
Need to match to the passenger side body line
speedster 2.png (323.14 KiB) Viewed 526 times
Post by TXGOAT2 » Thu Oct 23, 2025 11:46 am
Similar, but not an exact match. Looks manufactured, and manufactured speedster bodies probably had variations within a single maker's products over time.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Oct 23, 2025 12:42 pm
To my eye, it looks to be a closer match to the Model "C' in the advertisement. The louvered hood and the cowl to hood transition angle are very similar to the drawing. The car in the photo looks to have taken the suggestion in the advert to remove the stock Ford fenders, running boards and splash aprons, but it still appears to be running the stock Ford radiator as described in the advert copy for the "C" version.
Keep crankin',
Eric
Post by RajoRacer » Thu Oct 23, 2025 12:54 pm
The cowl line is "swept" back on the advertised body unlike the one in the photo - it's straight - not the same.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Oct 23, 2025 1:15 pm
Regardless of the make and model of a particular manufacturer, to answer the original question, it looks to me like a manufactured body not a homemade body.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu Oct 23, 2025 9:53 pm
Looks similar to C. But you have to remember that the same bodies were sold under a variety of names.
Andy
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Fri Oct 24, 2025 12:57 am
Manufactured. There were so many short lived manufacturers its hard to pinpoint the exact manufacuturer of some of these bodies.
Post by TRDxB2 » Fri Oct 24, 2025 1:50 am
Hard to match it, but some similarities. The builder of the car did make some modifications to the original design.
Top of back seat, length of cowl, steering wheel close to dash.
This link has the instructions for thr RED-I-Cut need to scroll down https://www.mtfca.com/discus/messages/3 ... 1386522911
