1926-27 T Pickup Bed Center Pan
TA Man
Topic author - Posts: 6
- Last Name: Partain
I'm looking for anyone who has an original "FLOOR REAR CROSS MEMBER HOUSING" for the 26-27 T Pickup Bed. This is the center pan that is located over the rear crossmember. I'd like to get some profile photos of the pan out of the bed, but in the bed would be ok too. Also, does anyone have the T part number for this piece?
Re: 1926-27 T Pickup Bed Center Pan
Are you sure it's called a housing? I thought it was a cover?
Dan
good luck...you should get what you're looking for...99% of us know what you're talking about and what you call it makes no difference.
welcome to the affliction!
T-48815 is part number of the '26-'27 Housing (rear cross member) as noted in the Price List of Body Parts book.
Lang's used to sell that part as Lang's # PBEDAD, but no longer avail, these were made by Howells a few years ago.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
You should do your homework.Original Smith wrote: ↑Fri Oct 24, 2025 3:12 pmAre you sure it's called a housing? I thought it was a cover?
- First Name: Henry
- Last Name: Lee
uhmmmmmmm Hey Moe Hey Larry.......,,,,,, Ouch..., Ouch...., Stop It!
TA Man
Hey guys, thanks for the info on the pan, the photos are great and part number too.
It's my understanding that the pan is kind of humped up in the middle between the strips, where the Model A pan is all flat across the top. I'm guessing that the rear crossmember needed just a little more clearance under the pan on the T than on the A.
I may see if I can get the drawing for this from the Benson Archives.
Does anyone have a photo of the top profile showing the hump?
varmint
- First Name: Vernon
- Last Name: Worley
There are three photos in this recent thread of it installed correctly.
https://mtfca.com/phpBB3/viewtopic.php?f=2&t=49974
Vern (Vieux Carre)
TA Man
Thankyou for the link to that thread!
