What do I have here ?
Dave1
Topic author - Posts: 117
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
I acquired this “gem” a while back with some other junk.
It is a KW model ALC,…. Thinking it is a magneto?
Anyone have any information??
Re: What do I have here ?
Post a picture as it would help.
Dave1
- Last Name: Eddie
Tried to post a picture, would not load
Dave1
- Last Name: Eddie
Dave1
- Last Name: Eddie
[image][/image]
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Edit the photo
Trimming it by a little goes a long way to reducing its file size
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Click on photo. Hit edit. Resize to 80 %. It will load.
- First Name: Adrian
- Last Name: Whiteman
Yes, that is a magneto from the 1900's: https://oldcroak.com/k-w-ignition-company-magnetos/
The 'ALC' has five magnets, is for ignition and lighting and cost (in 1909) the sum of $50.
- Last Name: Tannehill
- Board Member Since: 2002
I am alway amazed at the knowledge that is our members have! Well Done!
Dave1
- Last Name: Eddie
Thanks !
Now I know
Now I know
Dave1
- Last Name: Eddie
A Whiteman,
Thanks for posting the information on the K-W magneto.
Reading the catalogue description,
"I am guessing" that in the case of a model T this would be used in the event of a Ford magneto failure.
In 1910 the Ford magneto was the only source of ignition, (this was pre generator models), and repairing the magneto meant removing the engine, which is not a simple job.
Installing a K-W magneto would get you back on the road pretty quick (although $50.00 in 1910 would have been a lot of money)
It looks like would you drive it from the front crankshaft pulley with a flat belt.
Not sure what you would do about the Fan?
Anyway this is interesting stuff!
Dave
Dave
