Battery Cost Inflation
J1MGOLDEN
Topic author - Posts: 1323
- Last Name: Golden
Has anyone bought a 6 Volt, Group 1 Battery for their Model T lately?
The same major brand that I bought three years ago that was $75.00 with a trade in battery is now $155.00 with a trade in battery.
One auto parts store still has them for $114.95 with a trade in battery.
Both stores still add $15.00 for a no trade in sale.
A severe case of sticker shock for me, but I bought the high price battery!
Will
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Re: Battery Cost Inflation
Everything has gone up, I agree, I just had to buy a battery for my 40 Chevy and it cost me 110. The pumpkin pies I used to get a my local Public's cost more and are much smaller than last year. I'm guessing next year they will be selling it by the slice!
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
love2T's
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Have you bought an "innocent little 3/8" washer"? Try 29 CENTS EACH!!
Everything is totally out of control.
TMiller6
- First Name: Thomas
- Last Name: Miller
Yes, I bought a new 6 volt battery this year. I bit the bullet and purchased another Optima for $237 with no core charge.
They last longer. The oldest Optima AGM I have is twelve years old and my son brought it to me at the Old Car Festival this year to jump start my Model A that had the ignition left on all night. Every Optima I have purchased is still in use on my starter equipped cars. I write the purchase date on each with a permanent marker. I do a monthly rotation with a Battery Tender on each of them.
The Model A has floorboards over the battery that are screwed down underneath a carpet. My ‘26 Runabout has a battery door that requires a kid or a contortionist to access. Less battery maintenance is better.
The same logic applies to my daily use cars. The car I drive has “remove windshield wiper arms” as the first step in the battery replacement. Similarly my wife gets upset if her car doesn’t start. I am now buying AGM batteries for those cars as well.
Tom Miller
The value of the United States Dollar has gone down precipitously since around 2020. Efforts are underway to remedy that situation, against considerable resistance from various entrenched interests. Devaluing the dollar, also known as Inflation, raises the price of everything, discourages saving, and drives indebtedness. Most taxes are assessed in such a way that inflated prices and wages cause automatic tax increases. One dollar today is worth what about 4 cents was worth in 1910. (In 1910, there was NO income tax and NO "Social Security" tax.)
Who has that for $155 and was it a golf cart battery
Batteries bought online or mail order may carry substantial shipping costs by the time they reach you. Be sure you know the delivered cost at your end.
Are deep cycle batteries suited for automotive use?
varmint
- First Name: Vernon
- Last Name: Worley
Yes, a deep cycle battery can work in a car. Maybe not on new cars. I use one in a 1953 Chevy.
Vern (Vieux Carre)
Deep cycle batteries are NOT good for starting a car because they are not designed to provide the high-burst of power needed for an engine's starter motor. They are built to supply a steady, low amount of power over a long period. Starter batteries, which are made for a large amount of current over a short duration.
Having said that Deep Cycle batteries are great for Model T's without starters. But you don't need big ones; ones for trolling motors, winches, ride-on toys...etc 7Ah or better
Shrshot
- First Name: Kent
- Last Name: Palazzo
- Board Member Since: 2024
That's not true. Deep cycle batteries are designed to be discharged down to 20% of the AH rating and recharged over and over again. A starting battery does not have the same reserve capacity as deep cycle. But if both are 12VDC the only things that control amount of current are number of plates in a flooded cell battery and CCA. In short YES a deep cycle battery can be used in automotive use. I ran deep cycle batteries in my semi for 19 years, because they lasted longer.TRDxB2 wrote: ↑Thu Oct 30, 2025 2:19 pmDeep cycle batteries are NOT good for starting a car because they are not designed to provide the high-burst of power needed for an engine's starter motor. They are built to supply a steady, low amount of power over a long period. Starter batteries, which are made for a large amount of current over a short duration.
varmint
- Last Name: Worley
I suppose that I did not tell the full story. I cut the battery tray on my Chevy and welded up an extension to take a larger battery than original, which has the CCA to get the job done. It's my understanding that deep cycle batteries can recover better from a discharge, whether the discharge is after a hard start in the cold or a long slow drain.
Vern (Vieux Carre)
Art M
- First Name: Art
- Last Name: Mirtes
I have seen recommendations that a deep cycle battery not be used n a car. But if it works for you, go for it. Forty years ago, I fabricated a battery support bracket to accommodate one. Before trying it, I put my car to sleep for 23 years. I bought a new group 1 battery when the car woke up, Group 1 costs less than a golf cart battery.
Art Mirtes
Art Mirtes
Friend is using one of these in his non-starter. Has a second one as a back for long trips
Note the size Length 5.94"; Width 1.34"; Height 3.94" weighs 2.38 lbs & its an AGM put it anywhere battery (tape it to the dash
Some of the increase will undoubtedly be due to US firms passing on the beautiful tariffs on imported batteries. These vary depending on the country of origin. I believe the minimum increase is at least 10%. There will also be business costs of implementing control/payment mechanisms for the impost.
There are many battery manufacturers in the USA marketing products under different Brand Names
Key companies with significant automotive battery manufacturing presence in the U.S. include:
East Penn Manufacturing Co., Clarios (makes OPTIMA), Stryten Salina LLC (Champion, Exide, Absolyte, Centra, and Fulmen), SK Battery America, Inc., Tesla, Inc., A123 Systems, LLC, & Ultium Cells, LLC
The real increase in cost is due to inflation. A $75 item in January 2021 now would expect to cost in Jan 2025 $91.08. That's about 20% inflation. Normal targeted inflation is 2% a year to indicate good economic growth.
Tariff increases are not always passed on to the consumer 100%. Companies still need to be competitive.
- Attachments
- inflation bidn.png (18.39 KiB) Viewed 4137 times
i would expect a market the size of the USA would have battery manufacturers. However, Many US companies have goods manufactured overseas. Mexico may not be overseas, but they do make Optima batteries, and their production is a target of the beautiful tariffs. The origin of manufactured goods is often disguised behind well known national brands and the promotion of company heritage. I call it brand washing. Australian companies do the same, hiding the country of manufacture in the small print. You need to look to find it.
Which US companies still make all their bib overalls in the USA?
RVA23T
- Last Name: C
I'm just glad we don't have to pay a tariff to read every post that contains a statement of displeasure about tariffs.Allan wrote: ↑Thu Oct 30, 2025 11:38 pmSome of the increase will undoubtedly be due to US firms passing on the beautiful tariffs on imported batteries. These vary depending on the country of origin. I believe the minimum increase is at least 10%. There will also be business costs of implementing control/payment mechanisms for the impost.
Should we ever need to pay for the privilege of political views imported from a foreign country while reading a posting on a Model T internet forum, I hope it will be charged in a dollar type currency that is about 53% less in value than the US dollar and hopefully not levied for each posting read.
- First Name: Henry
- Last Name: Lee
Geez Folks easy fix to all of this...., A Country Boy will survive!
Get 50 pounds of potatoes, 1 pound of zinc galvanized nails 2" long, cut #12 gauge solid copper wire into 2" lengths, and a spool of 12 gauge strained copper wire. Now start making series/parallel circuits and you just made a potato battery! When the battery dies you have french fries and a source for making fuel or vodka! WIN WIN WIN!
Science is fun!
Science is fun!
J1MGOLDEN
- Last Name: Golden
Did you know we had electric clocks before we had electricity plugged in to the houses to operate them?
They sold a kit with some material that worked as the electrolyte, a copper plate and an iron plate with two wires about 10 feet long that would be attached to those plates and went through a hole or window sill too attach to the electric clock.
A hole was dug outside the window for the electrolyte with the plates positioned a little different spacing from each other. Then the hole was covered with a slight dip for a few pails of water to soak in and make electricity.
The clock would stop sometimes during hot dry summers, so two buckets of water n the low spot would set it right for several more months.
So, in the old days, you could make your own battery with a few basic ingredients.
Richard, the "posting on a model T internet forum" entitled Battery cost inflation seeks an explanation for that inflation. There are many factors that contribute to inflation. The imposition of tariffs on imports is just one factor among many. That tariffs add to inflation is not a political proposition, it is an economic reality, a reality some seem to have difficulty recognising.
Allan from down under
The primary driver of dollar inflation is massive government spending and borrowing.
RVA23T
- Last Name: C
No I see the dead horse.Allan wrote: ↑Fri Oct 31, 2025 9:58 amRichard, the "posting on a model T internet forum" entitled Battery cost inflation seeks an explanation for that inflation. There are many factors that contribute to inflation. The imposition of tariffs on imports is just one factor among many. That tariffs add to inflation is not a political proposition, it is an economic reality, a reality some seem to have difficulty recognising.
Just can't wait for another complaint about it to be posted.
Oranges and lemons make good batteries, as does canning vinegar. Pure water does not conduct electricity, but most water is not pure. Just about anything dissolved in water will make it conductive to some degree. Salt, acids, and alkalis can make water a good conductor.
- First Name: Henry
- Last Name: Lee
And you can rebuild/rejuvenate your battery for about $25.00…., search YouTube!
J1MGOLDEN
- Last Name: Golden
Larry just sent me this note and suggestion.
Rural King Stores bought out the old abandon K-Mart stores and they offer a great Group 1, 6 Volt Battery and 750 CCA for $89.00!
They offer a two year warranty and are tax exempt with a Tennessee farm tax exempt card.
The batteries are made by Exide, in East Tennessee.
Do a Search for Rural King Stores to find one near you.
Adam
- First Name: Adam
- Last Name: Doleshal
Group 1 6 volt batteries are currently $115 around Southeastern Wisconsin. They were $50 in the early 1990’s. Adjusted for inflation they are probably $20 more in “today’s dollars” than they were 30 plus years ago. That’s pretty darn reasonable considering demand is probably 25 percent of what it was in the early 1990’s.
I recently took some T batteries to the scrapyard and was paid a little over $9 each based on weight so the $15 “Trade in” at the store is pretty reasonable too.
We often overlook when comparing what things cost back in the day and what the hourly wage was at that time.
https://www.bls.gov/data/inflation_calculator.htm
$50
Ford wages vary by job & location
Hourly pay for entry-level positions: Approximately $16.94 to $18.75 per hour.
Recent contract increases (UAW):
Assembly-line workers: $42.60 per hour (up from $32.05). or $340.80/day
Skilled trades: $50.57 per hour (up from $36.96).
8 hours x $18.75/hour = $150 a day... no real change
$50
Prior to 1913, there was NO income tax and NO "Social Security" tax. (Banks paid interest on deposits, too!)
- First Name: Henry
- Last Name: Lee
Frank…., AWESOME POST!
Inflation erodes wages, interest income, and savings while inflating taxes. It also promotes indebtedness.
J1MGOLDEN
- Last Name: Golden
Actually, the price is the same, but the value of the dollar has fell though the floorboards!
Today's wages
UAW union dues are typically 1.44% of gross monthly wages for salaried workers or an amount equivalent to 2.5 hours of straight-time pay for hourly workers
For everyone the tax on wages except retirees
Social Security Tax For 2025, the total tax rate is 12.4%, split evenly between the employer and employee, and only applies to earnings up to a maximum of $176,100. This means that employees are pay 6.7% and employers 6.7%
Medicare Tax - The Medicare tax, 2.9%. is a mandatory U.S. federal payroll tax that funds the Medicare program's hospital insurance. Employees pay 1.45% of their total wages & Employers pay 1.45%
Retirees Taxes
Social Security Tax is collected on your income ( so while your collecting Social Security payment the Government may be collecting Social Security on that plus whatever other income your have)
Single, Head of Household, or Qualifying Surviving Spouse Less than $25,000 0%
$25,000 to $34,000 Up to 50%
More than $34,000 Up to 85%
Married Filing Jointly Less than $32,000 0%
$32,000 to $44,000 Up to 50%
More than $44,000 Up to 85%
Married Filing Separately (and lived with spouse at any time during the year) Any amount Up to 85
Medicare Tax - Non working Retirees pay no additional tax except for High-income retirees may be subject to the 3.8% Net Investment Income Tax (NIIT), also known as the Unearned Income Medicare Contribution Surtax.
Then there is the Federal Income tax and State & Local Taxes on income
And then when you die..................................
"Death tax" referring to estate tax / inheritance tax, which are taxes levied on the transfer of property after an individual's death. The United States has a federal estate tax, and some states impose their own estate or inheritance taxes.
Exemption Amount: For 2025, an estate is only required to file a return if its gross value, combined with lifetime taxable gifts, exceeds $13.99 million per individual ($27.98 million for a married couple).
Tax Rate: Only the value exceeding the exemption amount is taxed, with a top tax rate of 40%.
Then the states
Retirees Taxes
Then the states
Corey Walker
- First Name: Corey
- Last Name: Walker
I used to always get my 6 volt batteries at Tractor Supply Co. I don’t have one on my T but have a 1947 Hudson 6. They never seemed to last and I’d have to put a charger on them in short order. I went to the Interstate Battery store about 4 miles from Tractor Supply and told them about it and inquired and one cost just shy of $200. Then the man told me that about 6 months ago they had started supplying the 6 volt batteries to Tractor Supply and they just put their label on them and somehow sell them for around $50 less. I bought one a couple years ago and last month was the first time it needed a charge to start. I don’t drive this car regularly and it might set for a month between starts. I would check the battery supplier before going there to purchase one, this was in Tyler, Texas but I’ll be getting another one there this spring. It still cost about $150, about double what they were not too long ago.
Battery warranties are not free. Warranties are essentially insurance.
Problems with a car's charging system, such as under or over-charging, can dramatically shorten battery life. Starters that are not in good condition are very hard on batteries. Any problems with cables, grounds, including engine to frame grounds, starter switches, or starter issues can mimic a bad battery when in fact the battery is OK, but the full battery power can't reach the starter or the starter has problems that cause it to draw more power than it should while delivering less torque than it should. The entire starting system and battery charging system need to be in good order. Beyond that, a well tuned engine that starts readily is necessary for best overall performance. That minimizes demand on the starter which will assure long starter and battery life.
