Smith form a truck.
Bob Pilkie
First Name: Bob
Last Name: Pilkie
* REQUIRED* Type and Year of Model Ts owned: TT trucks and speedsters.
Smith form a truck.
Post by Bob Pilkie » Mon Nov 03, 2025 12:55 pm
Hi I recently found a smith form a truck but it seems to have been made for a larger car than a model T. Does anyone have info on them. Did they make different models for other brands of cars. All I can find is the ones for model Ts.
Re: Smith form a truck.
Post by Allan » Mon Nov 03, 2025 9:34 pm
There were such devices which could be fitted to TT's to turn them into 2TT's. I do not know if Smith form-a-trucks made these. The 2TT I worked on had eliptical springs on the rear axle, an auxiliary transmission and a jack shaft to make the connection to the worm drive torque tube.
Bob Pilkie
First Name: Bob
Last Name: Pilkie
Post by Bob Pilkie » Mon Nov 03, 2025 11:57 pm
Hi Alan. I have one of those kits on a TT truck also. It’s made by Olson it’s a neat setup. Yes it has elliptical springs. And the wheelbase is longer by the length of the warford transmission. And the frame goes back past the rear wheels about 3 feet.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Nov 04, 2025 4:07 am
Hi Bob, I would be interested to see a picture of your 2TT setup if you could post a picture here :-)
Thanks Adrian
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Nov 04, 2025 4:14 am
Smith Form-a-truck kits were available for any car to convert to a truck, but as most cars of the time were T's, the form-a-truck became most associated with the Ford.
Period advertising for them listed Ford, Maxwell and Chevrolet with a $350 kit.
Post by Wayne Sheldon » Tue Nov 04, 2025 6:36 am
Before they began building exclusively for the Dodge Brothers (1920ish?), in the mid 1910s, The Graham Brothers manufactured make a truck kits to fit basically any automobile. Their advertising targeted mostly non-Fords, although they did also make kits for the model T. Their kits were mostly custom built, tell them what chassis you had and what you wanted it to be capable of hauling, and they would build the kit to fit your needs. As a matter of record, they did make a kit for a Stutz as well as the more common Cadillac and Hudson cars.
Bob Pilkie
First Name: Bob
Last Name: Pilkie
Post by Bob Pilkie » Tue Nov 04, 2025 12:31 pm
How do I add a picture here of my smith form a truck kit
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Nov 04, 2025 2:25 pm
Hi Bob, this post covers the process: https://mtfca.com/phpBB3/viewtopic.php?f=9&t=45439
Bob Pilkie
First Name: Bob
Last Name: Pilkie
Post by Bob Pilkie » Tue Nov 04, 2025 9:42 pm
Does anyone have a smith form a truck attached to a car other than a model T.
