Rajo bb headgasket
Shelbycsx
Topic author - Posts: 37
- Last Name: Clayton
Rajo bb headgasket
What's the best headgasket steel or copper?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Rajo bb headgasket
Steel works fine, but unless you are good about maintaining your coolant, they can rust out. Copper seals well and obviously won't corrode. Just my experience.
varmint
- First Name: Vernon
- Last Name: Worley
Assuming an OLD engine and assuming that you did NOT plane the block nor head, then maybe the best is a steel gasket with a copper coating.
Vern (Vieux Carre)
