A guy is selling a wipe on patina in a can for about $160 per quart.
It is suposed to bring back the shine, protect the rusty surface, and remaining finish from further damage.
Is this stuff really worth it?
Linseed oil?
Patina in a can
NHUSA
Topic author - Posts: 168
- First Name: Fred
- Last Name: Dimock
- * REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Patina in a can
NH - Where I used to live - not the carburetor !
love2T's
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Re: Patina in a can
Product name might help but at that price it ought jump outa the can and DO THE WORK for ya!!
There's some crap, yes crap, called Nevr Dull or something like that, that just plain is junk. I may still have the can of it somewhere that I'll give away!
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Patina in a can
Here is what some of the the railroad museums have been using to restore old paint that is “chaulked-out” and deteriorated. It brings back the color and a nice gloss/semi-gloss. Plus it adds a layer of protection over bare metal and rust. They just brush it on straight out of the can. I would bet that if the two products were tested side by side, they might be extremely similar…
The Penetrol is only $13 to $18 for a quart depending on where you buy it. It’s available at many hardware & home improvement stores.
George Mills
- Last Name: Mills
Re: Patina in a can
Fred,
I use something called OSPHO. it Likes slightly oxidized surfaces and converts that rust dust to something inert and dull black. It's one of those rubber glove things so ya have to be careful...and if left exposed once neutralized will again slowly rust... I mention it because my finish for everything not painted is pretty much linseed oil if I can coat it and hang it long enough to fully dry and you mentioned linseed oil
NHUSA
- First Name: Fred
- Last Name: Dimock
Re: Patina in a can
The stuff is called Poppy’s Patina.
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: Patina in a can
Here is what I have used on different occasions on different surfaces
Rust-Oleum 1 qt. Clear Varathane Oil-Based Exterior Spar Urethane, Satin
https://www.tractorsupply.com/tsc/produ ... in-2344764
Rust-Oleum 1 qt. Clear Varathane Oil-Based Exterior Spar Urethane, Gloss
https://www.tractorsupply.com/tsc/produ ... hane-gloss
Clear, Rust-Oleum Marine Coatings Gloss Spar Varnish-207008, 1 qt
https://www.walmart.com/ip/Clear-Rust-O ... t/52500347
And if it is a loose surface that I can not clean well
Zinsser Peel Stop Clear Water-Based Bonding Primer 1 qt
https://www.acehardware.com/departments ... rs/1371087
All of these are clear or slightly milky finishes that hold up well and do not need another coat for many years.
I like natural (barn fresh) looking cars so I leave them as is when/where possible and just drive them.
Mike
Mike
dykker5502
- First Name: Michael
- Last Name: Deichmann
Re: Patina in a can
Here is their webshop: https://poppyspatina.com/
Ford Model T 1914 Touring
