Firewall Brass Trim (Flat)
BRENT in 10-uh-C
Topic author - Posts: 451
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Is anyone still making, (-or does anyone sell) the flat brass Firewall Trim like was used on the edge of 1914 Firewalls??
TIA
TIA
t-time
- Last Name: Bruto
- * REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Firewall Brass Trim (Flat)
Try Restoration Supply Co in Escondido Ca
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
The 1913-14 brass trim is a “U” configuration. Be sure you get the right trim. For over 50 years these cars have been fitted with reproduction dash boards made of 3/4” cabinet plywood. The original solid laminated dash boards measured 13/16” thick. I hope they are available in both sizes, I had difficulty finding it when I replaced the dash in my ‘13.
Get a horse !
RGould1910
- Last Name: Gould
I don't know. The slight overhang didn't bother me. If it did, I'd veneer the plywood.
Lang's has that flat trim.
Might call to see if this flat has the 1/4" overhang, on both sides, isn't clear in the description or photo.
Did get some oval trim from Restoration Supply to put on the faux '12 firewall. Has lips on both sides to hide the wood edges of the firewall.
To me, a 13-14 is a sort of a U, but flat on the top and sides. The sides have a very slight U configuration on the edges.
- First Name: Henry
- Last Name: Lee
Larry is correct..., the rounded trim is actual for boats. I have to make it on a sheet metal brake in the past or use a power roller with 3/4" flat dies..., works either way.
Just Sayin
Just Sayin
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Thank you Sir. I have definitely considered either making it on my Pullmax by making a set of dies out of Delrin. I have even thought about using the same dies to flatten the Oval moulding however I have not been able to locate anyone who is stocking it. So what grade Brass did you use and who was your supplier??Henry K. Lee wrote: ↑Fri Nov 14, 2025 5:36 pmLarry is correct..., the rounded trim is actual for boats. I have to make it on a sheet metal brake in the past or use a power roller with 3/4" flat dies..., works either way.
Just Sayin
- First Name: Henry
- Last Name: Lee
Online metals has whatever you need. They give you options in grades.
- Last Name: House
Henry Lee said “The rounded trim is actually for boats.”
Not so fast Hank. Here is an example of quite a bit of rounded trim I acquired off a salvaged 1910-1911 REO.
- First Name: Henry
- Last Name: Lee
REO yes....., Ford no. You must anneal the rounded brass or you will kink it. You think Henry Ford would have added extra steps in that? Flat can be slapped with a mallet with a light edge support.
