Update on Ignition Coil Points Availability
Ron Patterson
Topic author - Posts: 41
- First Name: Ronald
- Last Name: Patterson
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
Today I spoke to the manufacturer of Model T Ford ignition coil point sets and supplies them to Model T parts vendors.
As reported in mid-September the supplier of the four basic coil point stampings is still having problems sourcing the raw brass and steel to make these parts. At this time, there is no delivery date for the material needed.
The manufacturer has all the tooling set up and operating to finish the point sets when the stamped parts become available. Obviously, absent the basic stamped parts he is unable to provide the assembled points sets.
As you can well imagine, the manufacturer is just as frustrated with this situation as those who are unable to purchase points for coil repair. At this point we all can do is be patient.
The manufacturer has agreed to keep me posted (I am his best customer) and I will report on any updated status I receive on this Forum.
Ron Patterson
Ron Patterson
Re: Update on Ignition Coil Points Availability
Thank you, Ron.
Mark Chaffin
- Last Name: Chaffin
We happened upon a 100 sets misplaced in overstock. Give us a call. While supplies last. Chaffin's Garage (951) 226-7331
Brent Mize
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Mark,
I’ll take 50 sets. That will leave some for someone else that may need them.
Brent Mize
The Coil Doctor
Brent Mize
The Coil Doctor
Mark Chaffin
Give Dave a call at the Garage on Monday. He will be happy to fill your order.
Brent Mize
- First Name: Brent
- Last Name: Mize
Will do.
I will take all of them. I’m splitting them with David Woods.
Thanks so much.
Brent
The Coil Doctor
Thanks so much.
Brent
The Coil Doctor
- Last Name: Juhl
Coil points..... now there's an item that can cause real trouble for model t'ers down the road if supplies dry up. Another example of how we are dependent upon so many small suppliers to keep the hobby going. We must do our best to support all those who support us.
Properly adjusted coils and proper capacitors in good condition will extend point life.
- First Name: Keith
- Last Name: Townsend
Ron,
I dont know anything about coil point production.
Would it be feasible to put new tungsten on old coil points? I don't know of a single Model T owner who doesn't have a coffee can full of old points that are generally serviceable, but the tungsten is shot.
Keith
Keith
It might be possible to put tungsten points from common later model point sets on the T parts. They'd need to be similar in size and weight. The tungsten (or platinum?) is bonded to a small steel slug, and the steel is attached to the brass or spring steel part. Old points can be filed, up to a point.
Moxie26
- Last Name: Jablonski
CHAFFIN'S has always , I repeat. Always , been more than fair to the average Model T guy..... I'm sure his mode of business will not change.
What about just filing down the points just enough to smooth them out. I’ve got lots of them taken off and kept a bunch of them. That may not be the best thing to do but if you don’t drive a T all that much it would work OK. My opinion.
Maybe that’s the reason my Grandfather kept several copper head gaskets and boxes of old coils/ points, and miscellaneous T parts.
What did T owners do during WW2 with all the brass that was used for the war effort. Makes you wonder.
Maybe with the luxury of having common T parts readily avaliable weve forgotten how to repair some of our T parts as our earlier T owners did. Just another opinion.
You can file points IF there is still tungsten left on the little button. It's not all tungsten. If you file off all the tungsten, the points won't run long without sticking or burning. Older sets may have a thicker tungsten "biscuit" than newer production. An old junkyard guy told me that older points had more tungsten than newer ones. That was about 1962.
JohnH
- Last Name: Hunter
- Board Member Since: 2002
The E-Timer is one way out of points unavailability, since they are not necessary for the coils to function.
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
Using a Mastercoil, You only need one to make the four coils buzz.
André
André
Ron Patterson
The following sentence posted elswhere on this Fourm is patently false.
"The present manufacturer of the KW coil style ignition points has ceased production due to reasons not fully explained."
Ron Patterson
Ron Patterson
