Does anyone have an alternator conversion on their T?
Jeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Jeff » Tue Nov 18, 2025 6:43 pm
Does anyone have an alternator on their T? Buckeye sells them and states this on their website about them:
"The 12-volt version is capable of 80 amp output; the 6-volt version is capable of 40-amp output"
Model T's only have 12 AWG wiring in the charging circuit... and its 100 year old wiring to boot, nowhere near the ability to handle that kind of power if the alternator decided to put out it's max power.
Anyone seeing any issues?
Jeff
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
www.modeltregulators.com
www.modeltstarters.com
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Re: Does anyone have an alternator conversion on their T?
Post by Will » Tue Nov 18, 2025 7:04 pm
Yes, I have 12V alternator, I love it. Many trouble free miles. Its from Larry Becker. Its about 13 years old or so. Of course we lost Mr. Becker a few years ago. His famous saying was as long as he was here it was guaranteed. I have his 12 volt starter also. Never a problem.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Last Name: Strange
Post by CudaMan » Tue Nov 18, 2025 7:23 pm
My '24 came to me with a Becker 6V one wire alternator. It has worked perfectly for the 12 years (and counting) that I've owned the car. :)
Moxie26
Last Name: Jablonski
Post by Moxie26 » Tue Nov 18, 2025 8:54 pm
We also had the Larry Becker 6 volt alternator with a self-contained regulator on our 26 Runabout for 15 years, with no problems... Seem to be the only fix since going through a few Fun Projects regulators on the generator . Now running a fine generator and regulator detailed and rebuilt ...... By Jeff Stevenson..... Do you know him ???...... Thanks again.
davet753
First Name: David
Last Name: Thomas
* REQUIRED* Type and Year of Model Ts owned: 1927 Runabout Sport
Post by davet753 » Wed Nov 19, 2025 6:41 am
I run a 6-volt alternator from Snyders - no issues at all. I’ve never noticed more than about 15 amps maximum charge rate on the ammeter. Once the battery’s fully charged, it slowly drops off to just a few amps.
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Post by Nunsio1 » Wed Nov 19, 2025 7:19 am
I have a Buckeye Altenator w/ 12volt conversion. Only 1 problem with Bering failure after years of good operation. Buckeye replaced the unit quickly, good folks to deal with & a good quality product. Also using 12Ga input wire, good idea to install fuse link on input wire & if you're running a stock engine and trans, put blue Locktite on altenator case screws to prevent them from becoming loose from the normal vibration.
John M
Oscoda, Michigan
Post by Jerry VanOoteghem » Wed Nov 19, 2025 9:09 am
I don't believe there was any question as to whether or not alternators can be dependable.
The question seems to be whether or not the possible 40A - 80A output concerns anyone. I suppose a battery with an internal short, or a short anywhere else the charging circuit, could trigger the max alternator output which would quickly fry wiring, etc. Do users of alternators commonly also install fuses?
I really don't have a dog in this fight, since I do not, and would not, use an alternator, but I do find the question interesting.
Moxie26
Post by Moxie26 » Wed Nov 19, 2025 9:19 am
Just because an alternator's output, maximum output is listed, it's thanks to the internal regulator that controls the charging to the battery. In the years I was driving with that alternator on a 6-volt system, never once did I see the amp meter exceed 10 amps of charge , engine running after starting, settling slightly above zero a few minutes later.
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Wed Nov 19, 2025 9:43 am
I have had a 6V on mine for about 2 years. It has been trouble free. I had a rebuilt generator on it and then the cut-out failed. This was the quickest fix for me. Chaffins had it in stock and shipped to me in just a few days.
Post by TXGOAT2 » Wed Nov 19, 2025 9:53 am
I seem to remember reading of some alternator problems that may be heat/vibration related. That could be related to the T's gear drive and direct mount to the engine, rather than a bracket mount and belt drive. Or it could be related to improper gear lash. If I was worried about short circuits, I'd use fuses as appropriate. The stock T wiring is connected to a battery capable of delivering several times more current into a short than an alternator... with no fuses. Mounting the alternator to the block with an open spacer/adapter and a woods-type rubber drive coupling would probably be ideal. A bracket and belt arrangement using something like a timing belt to run the fan and alternator would be much cheaper.
