A type of removable band ear I've never seen
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Post by Dave Young » Wed Jan 31, 2024 5:18 pm
I pulled these bands out of a buddies car while doing a clutch repair. I've never seen these and don't really like the way they seem to fit. Reluctant to re-use them... thoughts?
Re: A type of removable band ear I've never seen
Post by speedytinc » Wed Jan 31, 2024 5:40 pm
They are a neat modification on non demount-able OEM bands.
Rather ingenious. in fact they are easier to re-install than the oem slotted type.
The ear gets placed on the T post @ an angle & gets rotated into position.
You may need to do some bending to the end for the ear to snap in over the post in tension,
just as is done on later demount-able band ear tabs onto the band.
The ear should not wiggle when installed.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Wed Nov 19, 2025 9:08 pm
plonkarchivist wrote:
Wed Jan 31, 2024 11:41 pm
You might have to bend the end slightly for the ear to snap over the post under tension, similar to what is done with later demountable band ear tabs onto the band.
That's your first post here? :shock:
T4Tom
Last Name: Magee
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Post by T4Tom » Wed Nov 19, 2025 9:53 pm
Careful! Those two posts are spam or some kind of scam. Note the inclusion of websites and email.
I hope admin hops on this.
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Wed Nov 19, 2025 10:27 pm
I sent a PM to AdminJeff about them a while ago.
Post by Jerry VanOoteghem » Thu Nov 20, 2025 6:48 am
Those bands are good wall hangers and conversation pieces. Use the real thing.
Post by speedytinc » Thu Nov 20, 2025 8:22 am
It's a word for word copy of my old post.
TrentB
First Name: Trent
Last Name: Boggess
Post by TrentB » Sun Nov 30, 2025 9:41 am
They are probably genuine Ford parts that the Ford engineers referred to as “Experimental Manufacture”. Ford was continually experimenting with new designs to solve problems or lower manufacturing costs. Some examples of these include clutch disc drums with spiral grooves in the inside face to improve oil flow to top hat transmission bushings, and clutch release fingers made from several layers of stamped steel (that one didn’t work out too well). These modifications are documented in the record of changes associated with the part. IF we could get access to The Benson Ford Research Center we could verify these transmission band ears were real and when they were used. Unfortunately the Benson Ford has been closed to researchers since COVID.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Nov 30, 2025 10:36 am
Trent,
I did not know that the Benson Research Center was not open. I have neen wanting to make a trip and had hopped to recruit you as a guide!
Keith
Post by DanTreace » Sun Nov 30, 2025 1:33 pm
Been closed to visits, but very responsive to email inquiries, and to mail. Have most recently used printed request form to get emailed pdf of Record of Changes, all you need is factory number and pay small fee via check or credit card.
Most recently, info on clutch discs
Property of The Henry Ford used with permission.
